I glued some Aqara contact sensors to mouse-traps in my attic so I don’t have to climb up to check on them every day - it’s worked well for there last couple of years.
I am now trying to have a nice status on my dashboard board and wrote the following template based on examples I have found online (thanks to those guys for sharing).
- name: "count of mouse traps"
state: >
{{ states.binary_sensor
| selectattr('attributes.device_class', 'eq', 'door')
| map(attribute='state')
| select('eq', 'on')
| list | count
icon: >-
{% if is_state('sensor.count_of_mouse_traps', '0') %}
mdi:check-circle
{% else %}
mdi:rodent
{% endif %}
Whilst I only have 2 traps, I like to future-proof things so I don’t have to keep modifying everything every time I add a new sensor. Right now, I only have 2 contact sensors and they are both being used for this purpose. However, I will add some sensors for doors and windows and so the template will no longer work.
I have tried to replace the device_class line as follows to separate the traps from the potential door sensors but I get the error UndefinedError: 'homeassistant.util.read_only_dict.ReadOnlyDict object' has no attribute 'icon'
| selectattr('attributes.icon', 'eq', 'mdi:rodent')
I am struggling to find documentation that explains properly how to write sensors that use select(), selectattr(), rejectattr(), map(). Can anyone point me in the right direction (domination wise and/or howe to do this).
thanks!
