I’ve got a template sensor that shows the amount of rooms with motion and the amount of lights turned on. Now this used to be dynamic and change when states were changed, however for some reason it’s become static and only shows states on boot.
I’ll be honest I’m not sure what rev I was on when it last worked (as there seems to have been loads recently) but I can confirm it doesn’t work now on the latest build (well it doesn’t change when the states change).
It was a release before 0.81.0 and you didn’t read the release notes before upgrading.
Template sensors will no longer auto update if we can’t find relevant entities in the template. You’ll want to review your template sensors and consider adding relevant entity_id entries or use the new homeassistant.update_entity service.
