I use the following template sensor to calculate number of hours since my cat feeder was last run.
dev_feeder_hours_since_fed:
entity_id:
- sensor.dev_feeder_last_fed
value_template: >
{% set time = as_timestamp(now()) - as_timestamp(states('sensor.dev_feeder_last_fed')) %}
{{ (time / 3600) | round() }}
If I plug that into the template editor it gives me the correct value (at the moment that would be 5) – But the sensor itself reads 0.
More detail: After restarting home assistant the sensor works fine and reads the correct number of hours, but as soon as I feed the cat and the time value for sensor.dev_feeder_last_fed
is updated with a new time, the sensor goes to 0 and stops updating itself after that. Just sits at 0 forever.
Any idea why it won’t update? My search for solutions yielded a lot of threads about last year’s breaking change requiring inclusion of entity_id
in the template config. I’ve done that, but I’m wondering if I’ve done it wrong…?
