I am trying to solve this, but seems I got stuck: I have multiple sensors that output text or numbers as values. I want to create a new template sensor now that shows every X seconds the current value of those existing sensors. So the value of the new template sensor would cycle every X seconds through the values and then start again.
The reason behind this is a KNX BUS based display in my house, that can only show one sensor/value, but I would like to see more values from different sources there.
For now I have this, but it is not cycling though the values, it is just sticking with value1:
sensors:
switch_sensor:
value_template: >
{% set values = ['value1', 'value2', 'value3'] %}
{% set index = (now().second // 5) % 3 %}
{{ values[index] }}
What I still need to solve is, use the real sensor entities and get it to cycle. So for it is not going through the values every 5 seconds.
Any help or suggestion I would be really happy about. Thank you!
Templates that use now() only update every minute. You will have to create a triggered template sensor and use a time pattern trigger ( seconds: "/5" ) if you want it to update every 5 seconds.
Replace your list of values with the states() function to get entity states. e.g.
{% set values = [states('sensor.foo'), states('sensor.bar'), states('sensor.foobar')] %}
Thanks a lot for your hint @tom_l !
My working solution looks now like this:
I have a automation that triggers every 5 seconds a index template sensor. And based on this index template sensor the “real” sensor I would like to use, cycles through the list of other sensors.
Sensors:
sensors:
knx_switch_sensor:
value_template: >
{% set index = states('sensor.knx_switch_sensor_index') %}
{% set values = [states('sensor.watermeter_main_value'), states('sensor.daily_pv_generation'), states('sensor.apc_ups_servers_current_real_power')] %}
{{ values[int(index)] }}
sensors:
knx_switch_sensor_index:
value_template: >
{% set index = now().second // 5 % 3 %}
{{ index }}
While the legacy template sensor platform will continue to be supported for the foreseeable future it will not be getting new features, like state_class.
Thank you @tom_l ! I was not aware of this new template feature. Thats super cool!
I will make sure to use that more in the future! Yours is the far better working solution!
If you don’t need the entity for other means, you could use an automation instead of the template and use knx.send as action and template the payload: key.
