I cant get this to work. The states not there when rendering is logical. But it doesn’t work after some time when state changes. Where do I go wrong with my icon-logic?
- sensor:
- name: "Yahoofinance MMRI"
unique_id: yahoofinance_mmri
state: >
{% set US10YR = states('sensor.yahoofinance_tnx') | float %}
{% set DXY = states('sensor.yahoofinance_nyicdx') | float %}
{{ ((DXY * US10YR)/1.61) | round(1, default=0) }}
attributes:
icon: >
{% if trigger.from_state.state < trigger.to_state.state %}
mdi:trending-up
{% elif trigger.from_state.state > trigger.to_state.state %}
mdi:trending-down
{% else %}
mdi:trending-neutral
{% endif %}
Log:
2023-12-17 22:05:19.236 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: 'trigger' is undefined when rendering '{% if trigger.from_state.state < trigger.to_state.state %}
icon: mdi:trending-up
icon: mdi:trending-down
{% else %}
icon: mdi:trending-neutral
{% endif %}'
2023-12-17 22:05:19.237 ERROR (MainThread) [homeassistant.helpers.event] Error while processing template: Template<template=({% if trigger.from_state.state < trigger.to_state.state %}
{% else %}
{% endif %}) renders=2>
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 569, in async_render
render_result = _render_with_context(self.template, compiled, **kwargs)
