Template sensor Unavailable but working in developer tools
Hi Guys,
Please could i have some assistance.
I am trying to create a template senor that will return “On” if a physical sensors value is between 2 values set by input_numbers or “Off” if it falls outside. The template I have works in developer tools > Template but the sensor’s state appears as unavailable.
Here’s what i have tried:
binary_sensor:
      sensors:
        res1_safe:
            friendly_name: "Reservoir 1 pH Safe"
            value_template: >
                {% set upper = states('input_number.reservoir_1_ph_max') | float %}
                {% set lower = states('input_number.reservoir_1_ph_min') | float %}
                {% set current = states('sensor.reservoir_1_ph') | float %}
                {{ current >= lower and current <= upper}}
any help greatly appreciated!
check your log for errors. There’s only 2 reasons why this wouldn’t work:
  • You have 2 binary_sensor sections in configuration.yaml
or
  • {% set current = states('sensor.reservoir_1_ph') | float %} is causing an error because you aren’t supplying a default to float.
thank you!!!
this worked, all 3 floats needed the default:
binary_sensor:
      sensors:
        res1_safe:
            value_template: >
                {% set upper = states('input_number.reservoir_1_ph_maximum') | float(default=0) %}
                {% set lower = states('input_number.reservoir_1_ph_minimum') | float(default=0) %}
                {% set current = states('sensor.reservoir_1_ph') | float(default=0) %}
this is strange though…
my config is copied from a working live HA up to date env running on a Hyper V platform, the only difference now is this HA env is running directly on a physical x64 based machine… previously it never cared if floats had defaults or not but now it does!
Thanks anyway problem solved :smiley:
