I am templating the Yr-weather wind sensor using a arrow for displaying wind direction.
In the unit_of_measurement attribute, I want to set the abbreviation value N/NNE/NE/ENE/E etc. This atribute does not have a “_template”.
Any way of making the unit_of_measurement work?
homeassistant:
customize:
sensor.ha_update_available:
state_card_mode: badges
templates:
unit_of_measurement: ${entities['sensor.ha_latest_version'].state}
theme: >
if (state = 'Yes') return 'green_badge'; else return 'blue_badge';
Closing in, but not there. Is this Java or Python code? (Does not really matter since I can’t both).
What am I missing?
sensor.weather_wind_direction2:
templates:
unit_of_measurement: ${entities[‘sensor.weather_wind_direction2’].state}
theme: >
if (337.51 < state < 22.50)
return ‘N’
elif (22.51 < state < 67.50)
return ‘NE’
elif (67.51 < state < 112.50)
return ‘E’
elif (112.51 < statet < 157.50)
return ‘SE’
elif (157.51 < state < 202.50)
return ‘S’
elif (202.51 < state < 247.50)
return ‘SW’
elif (247.51 < state < 292.50)
return ‘W’
elif (292.51 < state < 337.50)
return ‘NW’
endif;
You are mixing the 2 up…
Theming is for the badge style, the UoM template is for the value of the UoM.
You’d have to create another template there to show in the badge-label
Aha, I see.
So, there is no way of making a logic to populate the unit_of_measurement. I have to get the state value from a sensor.
Is there a way to put the state value from the logic of sensor1 into sensor2?
platform: template
sensors:
friendly_name: “Weather Wind direction”
value_template: ‘{{ states.sensor.weather_wind_direction.state }}’
entity_picture_template: >-
{% if 337.51 < states(‘sensor.weather_wind_direction’)|float < 22.50 %}
/local/WindDirection/N.png
SET states.sensor2.state = S
i guess you can play around with that value in a template… there’s no end to it, just try the templates in the template dev-tools and see what happens.
suppose you could create an intermediate señor with a value_template of the wind directions, and use the state of that sensor in the UoM.
Keep it modular and maintainable .
doesnt the sensor.weather_wind_direction2’ give you that already? if so it should just work like that , no?
Got it. Works fine. Thanks so much!
I´ll publish the code after refining it a bit.
Sirs0ri
(Maxi)
April 5, 2018, 10:24pm
8
Would you mind sharing how you did it in the end? I’m struggling with precisely the same issue right now.
Thanks in advance!
metbril
(Robert 🇳🇱🇪🇺)
April 6, 2018, 7:58am
9
This isn’t working for me. Do I need something special, like custom UI?
I haven’t gotten around to make the 32 pictures for the wind compass jet. – At least decided not to make 360 pixs. Ill post it when done,
The code so far, based on the YR-sensor:
In the file custom.yaml (you need to install customUI).
sensor.wind_compass:
templates:
unit_of_measurement: ${entities['sensor.wind_compass_abbreviation'].state}
In the file sensor.yaml:
sensors:
wind_compass_abbreviation:
value_template: >-
{% if 354.38 <= states('sensor.weather_wind_direction')|float <= 5.62 %}
N
{% elif 5.63 <= states('sensor.weather_wind_direction')|float <= 16.87 %}
NbE
{% elif 16.88 <= states('sensor.weather_wind_direction')|float <= 28.12 %}
NNE
{% elif 28.13 <= states('sensor.weather_wind_direction')|float <= 39.37 %}
NEbN
{% elif 39.38 <= states('sensor.weather_wind_direction')|float <= 50.62 %}
NE
{% elif 50.63 <= states('sensor.weather_wind_direction')|float <= 61.87 %}
NEbE
{% elif 61.88 <= states('sensor.weather_wind_direction')|float <= 73.12 %}
ENE
{% elif 73.13 <= states('sensor.weather_wind_direction')|float <= 84.37 %}
EbN
{% elif 84.38 <= states('sensor.weather_wind_direction')|float <= 95.62 %}
E
{% elif 95.63 <= states('sensor.weather_wind_direction')|float <= 106.87 %}
EbS
{% elif 106.88 <= states('sensor.weather_wind_direction')|float <= 118.12 %}
ESE
{% elif 118.13 <= states('sensor.weather_wind_direction')|float <= 129.37 %}
SEbE
{% elif 129.38 <= states('sensor.weather_wind_direction')|float <= 140.62 %}
SE
{% elif 140.63 <= states('sensor.weather_wind_direction')|float <= 151.87 %}
SEbS
{% elif 151.88 <= states('sensor.weather_wind_direction')|float <= 163.12 %}
SSE
{% elif 163.13 <= states('sensor.weather_wind_direction')|float <= 174.37 %}
SbE
{% elif 174.38 <= states('sensor.weather_wind_direction')|float <= 185.62 %}
S
{% elif 185.63 <= states('sensor.weather_wind_direction')|float <= 196.87 %}
SbW
{% elif 196.88 <= states('sensor.weather_wind_direction')|float <= 208.12 %}
SSW
{% elif 208.13 <= states('sensor.weather_wind_direction')|float <= 219.37 %}
SWbS
{% elif 219.38 <= states('sensor.weather_wind_direction')|float <= 230.62 %}
SW
{% elif 230.63 <= states('sensor.weather_wind_direction')|float <= 241.87 %}
SWbW
{% elif 241.88 <= states('sensor.weather_wind_direction')|float <= 253.12 %}
WSW
{% elif 253.13 <= states('sensor.weather_wind_direction')|float <= 264.37 %}
WbS
{% elif 264.38 <= states('sensor.weather_wind_direction')|float <= 275.62 %}
W
{% elif 275.63 <= states('sensor.weather_wind_direction')|float <= 286.87 %}
WbN
{% elif 286.88 <= states('sensor.weather_wind_direction')|float <= 298.12 %}
WNW
{% elif 298.13 <= states('sensor.weather_wind_direction')|float <= 309.37 %}
NWbW
{% elif 309.38 <= states('sensor.weather_wind_direction')|float <= 320.62 %}
NW
{% elif 320.63 <= states('sensor.weather_wind_direction')|float <= 331.87 %}
NWbN
{% elif 331.88 <= states('sensor.weather_wind_direction')|float <= 343.12 %}
NNW
{% elif 343.13 <= states('sensor.weather_wind_direction')|float <= 354.37 %}
NbW
{% endif %}
wind_compass:
friendly_name: "Weather Wind direction"
value_template: '{{ states.sensor.weather_wind_direction.state }}'
#unit_of_measurement: 'degrees'
{% if 337.51 < states('sensor.weather_wind_direction')|float < 22.50 %}
{% elif 22.51 < states('sensor.weather_wind_direction')|float < 67.50 %}
/local/WindDirection/NE.png
{% elif 67.51 < states('sensor.weather_wind_direction')|float < 112.50 %}
/local/WindDirection/E.png
{% elif 112.51 < states('sensor.weather_wind_direction')|float < 157.50 %}
/local/WindDirection/SE.png
{% elif 157.51 < states('sensor.weather_wind_direction')|float < 202.50 %}
/local/WindDirection/S.png
{% elif 202.51 < states('sensor.weather_wind_direction')|float < 247.50 %}
/local/WindDirection/SW.png
{% elif 247.51 < states('sensor.weather_wind_direction')|float < 292.50 %}
/local/WindDirection/W.png
{% elif 292.51 < states('sensor.weather_wind_direction')|float < 337.50 %}
/local/WindDirection/NW.png
{% endif %}
poebae
April 6, 2018, 9:04am
11
Looks great! I’d love to see this integrated into the Custom Weather Card.
metbril
(Robert 🇳🇱🇪🇺)
April 6, 2018, 1:12pm
12
I’ll give this some thought
Sirs0ri
(Maxi)
April 7, 2018, 1:17am
13
Installing customUI finally did the trick for me, thanks for your detailed answer!
you shouldn’t post the same issue twice, I was helping you in the other thread…
groutley
(Glen Routley)
January 7, 2022, 6:26am
16
Did you post these Badge png’s anywhere?
I would really like to use them…
Right now my Badge is Blank
metbril
(Robert 🇳🇱🇪🇺)
January 7, 2022, 7:30am
17
groutley
(Glen Routley)
January 8, 2022, 3:17am
19
Thank you !
a few more icons than your code above uses !
I edited the path and file name for your original N.png to 0.png etc…
but for some reason I still get a blank badge.
I’ll keep playing.
