Hi, I have an existing template sensor that calculates the net power use for my home, which works fine, but I’m trying to create a new template sensor, based on the working sensor, that returns only “on” or “off” depending on whether the net power is positive or negative, so that I can create a sensor graph that shows red or green whether I’m consuming or exporting power.
I’ve read the Templating documenation but my code keeps getting rejected by Home Assistant (invalid config), even with several variations on the code.
I’ve tried:
net_power_state:
friendly_name: "Power Generation State"
value_template: >-
{% if states('sensor.envoy_net_power') | float > 0 %}
Off
{% else %}
On
I’ve also tried “if is_state”, “if state”, “if is_state_attr” and “if state_attr”. All with no joy. I’m missing something and I hope somone can point out where my syntax is wrong.
Thanks.
