I have some trouble with this Sensor Template:
template:
- sensor:
- name: PV Leistung Gesamt
state: >
{{ (states('sensor.zeverSolar_generated_power')|float + states('sensor.zeverSolar2_generated_power')|float)}}
unit_of_measurement: W
state_class: total
device_class: power
After an reboot of the HA the Value is missing until I click on “reload YAML-Configuration → Template Entities” in the Settings Section.
Maybe this is because bothe sensors (zeverSolar & zeverSolar2) are from an AppDaemon Script?
And the Sensor Values are not present at the point there the template is set up?
greeting
Christian
