Denniz
September 11, 2020, 7:02am
1
I’m trying to create a tempate sensor so i can show the value on a markdown card.
My Configurtation.yaml (part of it):
sensor: !include sensors.yaml
My Sensor.yaml
sensors:
not_there:
value_template: "{{ (( as_timestamp(now()) - as_timestamp(strptime('06.07.2018', '%d.%m.%Y')) ) / 0 ) | round(2) }}"
entity_id: sensor.date
friendly_name: 'Not there'
unit_of_measurement: "Days"
ui-lovelace.yaml:
- title: Home
cards:
- type: markdown
content: >
{{ states('sensor.not_there') }}
Whatever I do, even after restart, the card displays ‘Unknown’. What am I doing wrong?
arretx
(Jon Griffith)
September 11, 2020, 7:14am
2
Are you trying to get the number of days counted? This worked for me in the template editor.
{{ (((as_timestamp(now())) - (as_timestamp(strptime('06.07.2018', '%d.%m.%Y')))) / 86400 ) | int }}
I tried it and in the log:
ZeroDivisionError: float division by zero
Not sure why you’re trying to divide by zero, works when you remove that
Denniz
September 11, 2020, 10:41am
4
There went something wron with copy paste of my code…
sensors:
not_there:
value_template: "{{ (( as_timestamp(now()) - as_timestamp(strptime('06.07.2018', '%d.%m.%Y')) ) / 86400 ) | round(2) }}"
This is my code in sensor.ymal, but still Unknown on my card.
There is no problem with how I set this up? because I use different files, and with include sensor.yaml etc.?
I have another type of sensor in the same sensor.yaml file, a command line, and that works fine. I can show that value on a card.
petro
(Petro)
September 11, 2020, 11:34am
5
It’ll be unknown until the code executes, which is midnight. Also, this template won’t work in 0.115. Best to make that change now.
Also, as a side note, wouldn’t you always want this to floor? If your time was after 12pm, you’d have an extra false day added on.
sensors:
not_there:
value_template: "{{ (( as_timestamp(strptime(states('sensor.date'))) - as_timestamp(strptime('06.07.2018', '%d.%m.%Y')) ) / 86400 ) | round(2) }}"
Denniz
September 11, 2020, 11:48am
6
Okay, maybe i used the wrong code for the sensor, I took it from the documentation:
I added a new sensor to my sensor.yaml.
sensors:
test:
value_template: >-
"testing 1 2 3"
friendly_name: 'test'
To my knowledge, this sensor should just retun ‘testing 1 2 3’.
in my ui-lovelace.yaml i use
{{ states('sensor.test') }}
But still it displays ‘Unknown’
what does sensor.test
show in dev tools states page ?
Denniz
September 11, 2020, 2:22pm
8
it shows “testing 1 2 3”…
And… I just updated the hassio os, and it did reboot. And now I see the right value on my card. That raises a next question, do i need to reboot / restart before sensor.yaml does it’s job?
And is it possible to refresh a sensor.yaml with ‘platform: template’ with an interval like:
scan_interval:
minutes: 1
sensors:
test:
value_template: >-
"testing 1 2 3"
N.B. i know refreshing a static value does not make sense, but I want to do some things with date and time in the template.
petro
(Petro)
September 11, 2020, 2:31pm
9
you always have to restart when adding sensors to sensors.yaml. In version 0.115 you can reload the sensors file without restarting.
