Home Assistant version 229 (from Supervisor->System) installed from image for Raspberry Pi.
This is my first post here, so apologies in advance for any mistakes that I make.
Background:
I have a humidity sensor in a bathroom driving a fan, which is supposed to bring down humidity in the bathroom. The problem I have is that the general humidity (from the weather) is quite variable; triggering the directly from humidity means that I either have to set quite a high threshold before turning on the fan, otherwise, in times of high humidity the fan will run almost constantly. I did discover both template sensors and also filter sensors; From the humidity sensor, I created a filter sensor that does a ātime_simple_moving_averageā with quite a large (6 hour) window and then take the difference between the two in order to try to give me a value that I can trigger the fan from that would be something akin to when the bathroom humidity is above āambientā (for want of a better term?)
Code:
# Command-line sensor; CPU temperature...
# <SNIP>
# Filter Sensor(s) ...
- platform: filter
name: "Middle Bathroom Fan Average Humidity"
entity_id: sensor.sonoff_1000bed159_humidity
filters:
- filter: time_simple_moving_average
window_size: "06:00"
precision: 2
# Difference between Bathroom Humidity and rolling Average ...
sensors:
middle_bathroom_humidity_diff:
friendly_name: "Middle Bathroom Humidity Difference"
value_template: "{{ states('sensor.sonoff_1000bed159_humidity') | float - states('sensor.middle_bathroom_fan_average_humidity') | float }}"
The problem:
What I am seeing is strange; I see quite large negative spikes in the difference periodically that donāt match up with the values from the actual sensor and the filter sensor. The following graph should show what I mean:
The negative spikes appear to somewhat be linked to when the the difference reverses (i.e., crosses the zero-line), but not always.
Thanks in advance for any help that you are able to give!
sensor.sonoff_1000bed159_humidity is intermittenly becoming unavailable. Youāre casting the state unavailable to a float. Any string that is not a number that gets cast to a float using | float will turn into the default value of 0.0. So at that time you essentially have 0.0 - sensor.middle_bathroom_fan_average_humidity, which ends up with a negative spike. Fix your humidity sensor and youāll fix your issue.
@petro: Many thanks for that; makes perfect sense once explained.
WRT fixing the sensor; thatās not really a choice for me, at least in the short termā¦ Do you know if thereās a way to make the result of the calculation be āunavailableā if the base sensor is unavailable? ā¦Sort of like Cās ?: ternary operator?
I did try the following after reading the //Templating section of the docs, but it didnāt work:
@petro, Again, thanks. Works perfectly - of course!
I do feel kind of like I got you to do my homework for meā¦ Can you recommend a good place to learn how the template stuff works? The docs suggest the Jinja2 website, but I didnāt find it easy to follow; possibly because it seems to be HTML oriented, rather than Home-assistant -centric?
