This is driving me nuts and I can’t figure it out. I am trying to get my battery icon to show dynamically but the code is not working. Any ideas?
Here is the code:
sensors:
rear_gate_sensor_battery:
friendly_name: “Rear Gate Battery”
unit_of_measurement: “%”
value_template: >-
{%- if states.binary_sensor.rear_gate_opened.battery_level %}
{{ states.binary_sensor.rear_gate_opened.attributes.battery_level | round }}
{% else %}
{%- endif %}
icon_template: >-
{%- if is_state(“states.binary_sensor.rear_gate_opened.attributes.battery_level”, “unknown”) %}
mdi:battery-unknown
{% elif states(‘states.binary_sensor.rear_gate_opened.attributes.battery_level’) | float <= 5 %}
mdi:battery-outline
{% elif states(‘states.binary_sensor.rear_gate_opened.attributes.battery_level’) | float >= 95 %}
mdi:battery
{% else %}
mdi:battery-{{(states.binary_sensor.rear_gate_opened.attributes.battery_level | float / 10)|round*10}}
{%- endif %}
Here is the test:
Here is the result:
I have the same problem, did you perhaps find a solution? TIA.
keithh666
(Keith Hull)
July 25, 2017, 4:13pm
3
Try removing the single quotes " ’ "
Still having fun with this one. I have tried almost everything:
any ideas?
sensors:
back_gate_sensor_battery:
friendly_name: 'Back Gate Battery'
unit_of_measurement: '%'
value_template: {{ states.binary_sensor.back_gate_opened.attributes.battery_level | round(0) }}
icon_template:
{%- if 'states.binary_sensor.back_gate_opened.attributes.battery_level' == '100' %}
mdi:battery-charging
{%- elif 'states.binary_sensor.back_gate_opened.attributes.battery_level' <= '5' %}
mdi:battery-outline
{%- elif 'states.binary_sensor.back_gate_opened.attributes.battery_level' >= '95' %}
mdi:battery
{% else %}
mdi:battery-{{('states.binary_sensor.back_gate_opened.attributes.battery_level' | float / 10)|round*10}}
{%- endif %}
results in:
sensors:
friendly_name: ‘Back Gate Battery’
unit_of_measurement: ‘%’
value_template: 80
icon_template:
mdi:battery
I think you need >- on your icon_template: line. You also have quotes around your numbers, which I think makes them into a string comparison. What I use is below and looks fairly similar to yours except for handling the 5% and 95% use case.
sensors:
mailbox_battery:
value_template: '{{ states.zwave.mailbox.attributes.battery_level }}'
friendly_name: 'Mailbox Battery'
entity_id: zwave.mailbox
icon_template: >-
{% set battery_level = states('sensor.mailbox_battery')|int('unknown') %}
{% set battery_round = (battery_level|int / 10)|int * 10 %}
{% if battery_level == 'unknown' %}
mdi:battery-unknown
{% else %}
{% if battery_round >= 100 %}
mdi:battery
{% elif battery_round > 0 %}
mdi:battery-{{ battery_round }}
{% else %}
mdi:battery-alert
{% endif %}
{% endif %}
I like your icon template. But is there anyway of not getting this error at startup?
Could not render icon template Dørsensor Batteri: UndefinedError: 'mappingproxy object' has no attribute 'battery_level'
I use it for my zwave devices, so it is not ready at startup.
Wow!! Thanks for this @NotoriousBDG - I now have all my zwave devices showing dynamic icons for their batteries
Quick question though - I get the following error in my log at startup for all my zwave devices now though:
Could not render template Kitchen sensor, the state is unknown.
Any ideas how to avoid this error?
That’s most likely because battery devices sleep most of the time. It should show up once the device wakes up and reports in.
Thanks @NotoriousBDG , but it seems this is because the zwave devices aren’t “ready” at startup and only a few seconds later.
I found it worked by replacing the “value_template” you had above with the “value_template” as seen here .
No more error
Awesome. I’ll update my templates with that fix too.
Zepixir
January 24, 2018, 9:23pm
11
Tried this:
value_template: '{% if states.zwave.vannsensor_oppvaskmaskin %}
{{ states.zwave.vannsensor_oppvaskmaskin.attributes.battery_level }}
{% else %}
n/a
{% endif %}'
icon_template: >-
{% set battery_level = (states.zwave.vannsensor_oppvaskmaskin.attributes.battery_level)|int('unknown') %}
mdi:battery-unknown
{% else %}
mdi:battery
{% else %}
mdi:battery-alert
{% endif %}
{% endif %}
Still got this error:
Could not render icon template Vanndetektor Oppvaskmaskin Batteri: UndefinedError: ‘mappingproxy object’ has no attribute ‘battery_level’
Do you not get this error?
Your first line below icon_template is currently this:
{% set battery_level = (states.zwave.vannsensor_oppvaskmaskin.attributes.battery_level)|int(‘unknown’) %}
It should rather be this:
{% set battery_level = states(‘name of your sensor here ’)|int(‘unknown’) %}
Sorry, not sure what you are calling your sensor as you haven’t included that part of the code. In @NotoriousBDG ’s example, it would be sensor.mailbox_battery
Hope that helps?
Zepixir
January 25, 2018, 5:24pm
13
Yes! How could I miss that. Thank you, no more errors!
Zepixir
February 14, 2018, 10:40pm
15
Have a problem with my smokesensor templates. Get this error:
Could not render template Branndetektor Kjøkken, the state is unknown.
. Do you know if its possible to get this to work?
branndetektor_kjokken_template:
friendly_name: 'Branndetektor Kjøkken'
value_template: >-
{%- if is_state("sensor.brannvarsler_kjokken_smoke", "2") -%}
Brann
{%- elif is_state("sensor.brannvarsler_kjokken_smoke", "3") -%}
Brann Test
{%- elif float(states.sensor.timestamp_now.state | int - as_timestamp(states.zwave.brannvarsler_kjokken.last_updated)) | float > (5000) -%}
Error
{%- else -%}
Ok
{%- endif -%}
It is this line that is causing the problem:
Error
But really want that function, but meaby possible to fix?
Juggler
(SR)
July 4, 2018, 1:38am
16
Did you ever get this to work? I’m seeing similar errors, also with a Z-wave device. I’ve got the following in my sensors.yaml:
sensors:
battery_entry_sensor:
value_template: '{% if states.zwave.vision_unknown_type0004_id0000_2 is not none %}
{{ states.zwave.vision_unknown_type0004_id0000_2.attributes.battery_level }}
{% else %}
n/a
{% endif %}'
friendly_name: 'Door Lock'
icon_template: >
{% set battery = ['-outline','-20','-20','-30','-40','-40','-60','-70','-80','-90',''] %}
{% set charge = (states('battery_entry_sensor') | float / 10) | round %}
mdi:battery-{{ battery[charge] }}
for battery, why don’t you just use device_class: battery instead of the icon_template:
sensors:
corridor_motion_sensor_battery:
friendly_name: 'Corridor battery'
value_template: >
{{ states.sensor.corridor_motion_sensor.attributes.battery }}
# icon_template: >
# {% set battery_level = states.sensor.corridor_motion_sensor.attributes.battery|default(0)|int %}
# {% set battery_round = (battery_level / 10) |int * 10 %}
# {% if battery_round >= 100 %}
# mdi:battery
## {% elif battery_round > 0 %}
# mdi:battery-{{ battery_round }}
# {% else %}
# mdi:battery-alert
# {% endif %}
Juggler
(SR)
July 4, 2018, 10:41am
18
That was too easy… thank you!
Bhughes
(B Hughes)
May 14, 2019, 8:06pm
20
Hi, have tried several combinations of the suggestions here, but cant seem to get it working. The sensor always shows the battery-alert icon for all battery levels:
Running Home Assistant v0.92.2. Hope someone can find the error please?
configuration.yaml
