Hi
I’m trying to get my zigbee2tasmota tuya trv working in homeassistant. I try to read the valveposition, and try this, but I get an error:
Invalid config for [sensor.mqtt]: [value__template] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->value__template. (See ?, line ?).
This is my ocnfig
- platform: mqtt
availability_topic: "z2t/tele/LWT"
payload_available: "Online"
payload_not_available: "Offline"
json_attributes_topic: "tele/z2t/CB5D/SENSOR"
json_attributes_template: >
{% set properites = ["LocalTemperature", "TuyaTempTarget", "TuyaValvePosition", "LinkQuality", "TuyaAwayDays", "TuyaAutoLock", "TuyaAwayTemp", "TuyaScheduleHolidays", "TuyaScheduleWorkdays", "TuyaWeekSelect", "TuyaEcoTemp", "TuyaComfortTemp", "TuyaForceMode", "TuyaBoostTime", "TuyaChildLock", "TuyaPreset", "TuyaMinTemp", "TuyaMinTemp", "Manufacturer", "ModelId", "EF00<11", "EF00<24", "EF00/022C", "EF00/050D"] %}
{%- set json_template -%}
{%- for key in properites -%}
"{{key}}": "{{ value_json.ZbReceived['0xCB5D'][key] | default(state_attr('sensor.tuyavalve',key)) }}"{% if not loop.last %},{% endif %}
{%- endfor -%}
{%- endset -%}
{{ json_template }}
state_topic: "tele/z2t/CB5D/SENSOR"
value__template: >
{% if value_json.ZbReceived['0xCB5D'].TuyaValvePosition is defined %}
{{ value_json.ZbReceived['0xCB5D'].TuyaValvePosition }}
{% else %}
{{ state_attr('sensor.tuyavalve','TuyaValvePosition') }}
{% endif %}
the data i get from zigbee2tasmota
22:24:30 MQT: tele/z2t/CB5D/SENSOR = {"ZbReceived":{"0xCB5D":{"Device":"0xCB5D","Name":"zolderradiator","TuyaValvePosition":60,"Endpoint":1,"LinkQuality":76}}} (retained)
