jacoscar
(Jacopo)
November 19, 2024, 6:48pm
1
What is wrong here?
from configuration.yaml
sensors:
pompa_di_calore_on:
value_template: >
{% if states('sensor.shelly3em_potenza_totale')|float > 200 %}
1
{% else %}
0
{% endif %}
- platform: history_stats
name: Duty Cycle Pompa di Calore
entity_id: sensor.pompa_di_calore_on
state: "1"
type: time
start: "{{ now() - timedelta(hours=24) }}"
duration:
hours: 24
sensors:
duty_cycle_percentage:
unit_of_measurement: "%"
value_template: >
{% set total_time = 60 * 60 %} # 1 ora in secondi
{% set on_time = states('sensor.duty_cycle_pompa_di_calore')|float * 60 %} # Tempo acceso in secondi
{{(on_time / total_time * 100) | round(2)|float}}
You cannot use YAML comments n Jinja templates.
tom_l
November 19, 2024, 7:43pm
3
e.g. change
to
{% set total_time = 60 * 60 %} {# 1 ora in secondi #}
I was getting there @tom_l …
@jacoscar
I’m a little confused by the math you are using for the template sensor.
Your source sensor duty_cycle_pompa_di_calore
is the number of hours over the past 24 hours that the pump has been running.
The second line of the template is converting the source value into minutes of runtime, not seconds. So you are ending up with a unit of % min/sec
sensors:
value_template: >
{# Tempo acceso in ore #}
{% set on_time = states('sensor.duty_cycle_pompa_di_calore') | float(0) %}
{# Percentuale di tempo acceso per 24 ore #}
{{ ((on_time / 24) * 100) | round(2) }}
FWIW, the History Stats sensor supports doing this automatically if you use the ratio
type:
state: "1"
type: ratio
duration:
hours: 24
jacoscar
(Jacopo)
November 19, 2024, 8:48pm
5
Thanks, yes, I just noticed that; it was originally built using ChatGPT and the example was calculating the duty cycle in the last hour rather than 24h.
Removing the comments did the trick, thanks everyone!
