Template sensore with expirationdate doubled in home assistent
I have the following template sensor that is getting updated by a key_collector:
Problem is that in home assistant this entity is double:
One is from the ESP Home integration, the other from the MQTT.
Can i somehow prevent this ?
Remove one or the other from your esp device’s configuration.
Ok, But I only have one config in there with the template sensor. The expire_after somehow added the MQTT one
You have 2 in there. The MQTT section is providing sensor discovery.
