Template sensors that shouldn't be updated on reboot - energy consumption
Hello All!
I have 3 template sensors for calculating my energy consumption / solar production that are working aboslutely OK except when I reboot my HA when they spike. This causes the utility meters associated to also spike and mess everything up. What can I do?
This is what I have under sensor / platform template:
energy_consumed:
        value_template: "{{ ((states('sensor.energy_consumed_phase_1') | float + states('sensor.energy_consumed_phase_2') | float + states('sensor.energy_consumed_phase_3') | float) /1000) | round(1) }}"
        unit_of_measurement: "kWh"
        device_class: power
      energy_returned:
        value_template: "{{ ((states('sensor.energy_returned_phase_1') | float + states('sensor.energy_returned_phase_1') | float + states('sensor.energy_returned_phase_1') | float) /1000) | round(1) }}"
        device_class: power
      production_difference:
        value_template: "{{ (states('sensor.energy_returned') | float - states('sensor.energy_consumed') | float) | round(1) }}"
        device_class: power
I tried to recreate one of those sensor in the “new way” and only trigger it every 5 minutes but it doesn’t seem to work:
template:
  - trigger:
      - platform: time_pattern
        minutes: 5
      - name: energy_consumed_2
        state: "{{ ((states('sensor.energy_consumed_phase_1') | float + states('sensor.energy_consumed_phase_2') | float + states('sensor.energy_consumed_phase_3') | float) /1000) | round(1) }}"
        device_class: power
What am I doing wrong? How can I solve this issue?
Thanks!
Not sure on the first question but to get time_pattern to trigger every 5 minutes use:
  - trigger:
        minutes: "/5"
Also, I think you need to use device_class: energy if its in kWh ?
Power is in W or kW
You should add availability templates to prevent the glitching:
energy_consumed:
  availability_template: >
    {{ not ( is_state('sensor.energy_consumed_phase_1', 'unavailable') or
             is_state('sensor.energy_consumed_phase_2', 'unavailable') or
             is_state('sensor.energy_consumed_phase_3', 'unavailable') ) }}
  device_class: power
