simpic
(Simon Pickard)
July 9, 2020, 4:42am
1
Hi, I’m trying to use the platform: template syntax for the first time in my configuration.yaml.
I and using REST to grab data from the pws api at api.weather.com . I have defined the following in my configuration.yaml to grab that data along with the following sensors.
- platform: rest
json_attributes:
- observations
value_template: '{{ value_json["observations"][0]["obsTimeLocal"].title() }}'
resource: https://api.weather.com/v2/pws/observations/current?stationId=MYSTATIONID&format=json&units=e&apiKey=MYAPIKEY
scan_interval: 300
sensors:
pws_location:
value_template: '{{ states.sensor.pws_report.attributes.observations[0].neighborhood }}'
pws_station_id:
value_template: '{{ states.sensor.pws_report.attributes.observations[0].stationID }}'
pws_type:
value_template: '{{ states.sensor.pws_report.attributes.observations[0].softwareType }}'
pws_wind_dir:
value_template: '{{ states.sensor.pws_report.attributes.observations[0].winddir }}'
pws_wind_gust:
value_template: '{{ states.sensor.pws_report.attributes.observations[0].windGust }}'
pws_wind_speed:
value_template: '{{ states.sensor.pws_report.attributes.observations[0].imperial.windSpeed }}'
pws_humidity:
value_template: '{{ states.sensor.pws_report.attributes.observations[0].humidity }}'
pws_precip_total:
value_template: '{{ states.sensor.pws_report.attributes.observations[0].imperial.precipTotal }}'
pws_precip_rate:
value_template: '{{ states.sensor.pws_report.attributes.observations[0].imperial.precipRate }}'
pws_temp:
value_template: '{{ states.sensor.pws_report.attributes.observations[0].imperial.temp }}'
pws_solar:
value_template: '{{ states.sensor.pws_report.attributes.observations[0].solarRadiation }}'
My problem is that the sensors don’t seem to get defined as entities when reloading the file or restarting. I’m sure this is something to do with my lack of knowledge, so a pointer in the right direction would be very helpful.
Troon
(Troon)
July 9, 2020, 8:39am
2
It’s possible the value_template
is too complex for HA to work out what entity to watch. Try helping it — example for the first one, repeat for the others if it works:
sensors:
pws_location:
entity_id: sensor.pws_report
If that doesn’t fix it, what does sensor.pws_report
show in Developer Tools / States? Is there anything relevant in the HA log (under Configuration in recent versions, otherwise under Developer Tools)?
simpic
(Simon Pickard)
July 9, 2020, 9:16am
3
I think this might be part of the problem. Nothing shows in States.
I’m guessing this is because I can’t find any entities related to pws.
Seems they are not getting created.
Log file shows no issues.
Troon
(Troon)
July 9, 2020, 9:24am
4
You have restarted HA, haven’t you? Sensor changes still require a restart to get picked up.
Could you post what you get from the resource if you connect in a browser?
simpic
(Simon Pickard)
July 9, 2020, 9:30am
5
Yep, multiple restarts.
If I put the url into a browser it returns the data from the api…
{"observations":[{"stationID":"I90582228","obsTimeUtc":"2020-07-09T09:29:54Z","obsTimeLocal":"2020-07-09 19:29:54","neighborhood":"Macedon","softwareType":"EasyWeatherV1.4.7","country":"AU","solarRadiation":0.0,"lon":144.578995,"realtimeFrequency":null,"epoch":1594286994,"lat":-37.442001,"uv":0.0,"winddir":61,"humidity":89,"qcStatus":1,"imperial":{"temp":48,"heatIndex":48,"dewpt":45,"windChill":46,"windSpeed":5,"windGust":7,"pressure":28.72,"precipRate":0.00,"precipTotal":0.00,"elev":1539}}]}
tom_l
July 9, 2020, 9:48am
6
Can you paste the attributes of sensor.pws_report as seen in the developer tools / states menu?
simpic
(Simon Pickard)
July 9, 2020, 9:58am
7
The sensor.pws_report is not showing anywhere. I can’t see it in entities or states and no issues reported in the log.
Here is my configuration.yaml
default_config:
- platform: rest
json_attributes:
- observations
resource: https://api.weather.com/v2/pws/observations/current?stationId=I90582228&format=json&units=e&apiKey=MYAPIKEY
scan_interval: 300
sensors:
pws_location:
sensors:
# pws_location:
# value_template: '{{ states.sensor.pws_report.attributes.observations[0].neighborhood }}'
pws_station_id:
pws_type:
pws_wind_dir:
pws_wind_gust:
pws_wind_speed:
pws_humidity:
pws_precip_total:
pws_precip_rate:
pws_temp:
pws_solar:
solar_angle:
friendly_name: "Sun Angle"
unit_of_measurement: '°'
value_template: "{{ '%+.1f'|format(state_attr('sun.sun', 'elevation')) }}"
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
And the log file.
2020-07-09 19:54:57 ERROR (SyncWorker_14) [homeassistant.util.yaml.loader] mapping values are not allowed here
in "/config/configuration.yaml", line 6, column 6
2020-07-09 19:55:29 WARNING (MainThread) [homeassistant.components.ring] Error fetching Ring device data: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
2020-07-09 19:56:10 WARNING (SyncWorker_7) [homeassistant.components.sonos.media_player] Could not connect media_player.pool_2: Connection error: HTTPConnectionPool(host='192.168.1.198', port=1400): Read timed out
The ERROR is where I stuck some crap in the configuration.yaml to make sure it was reading the correct file. It is!
tom_l
July 9, 2020, 10:18am
8
See if the sensor shows up when you try this, and just for this test remove json_attributes:
value_template: '{{ value_json["observations"][0]["obsTimeLocal"] }}'
simpic
(Simon Pickard)
July 9, 2020, 11:07am
9
Thanks for the suggestion.
I’ll try that in the morning.
Troon
(Troon)
July 9, 2020, 11:14am
10
You’re missing the top-level sensor:
ahead of the first template sensor description. Like this:
default_config:
- platform: rest
# etc
simpic
(Simon Pickard)
July 10, 2020, 2:02am
11
Thanks, I knew it was going to be something simple!
I can now see all the data in the pws_xxx sensors in entities.
Now I need to figure out how to do something with it. I would like to be able to get alexa to read out the temp. Not sure if that is possible, but I’ll have a go.
