It took me a while to figure this out, so I just thought I would share in case it helps someone else out for their project, or general HA programming understanding.
You can paste the following into your Developer Tools->Template, to get a list of all offline Zigbee/ZWave Devices, should be easily extensible to other integrations also.
{% set result=namespace(offline_devices=[]) %}
{% set integrations=['mqtt', 'zwave_js', 'zha'] %}
{% for integration in integrations %}
{% for device in integration_entities(integration) | map('device_id') | sort | unique | list %}
{% for entity in device_entities(device) %}
{% if entity.startswith(('switch','sensor','binary_sensor')) and "unavailable" in expand(entity)|string %}
{# add error checking, in case name_by_user==None #}
{% set device_name=iif(device_attr(device,"name_by_user"), device_attr(device,"name_by_user"), "ERROR", device_attr(device,"name")) %}
{% set result.offline_devices= result.offline_devices + [device_name] %}
{% endif %}
{% endfor %}
{% endfor %}
{% endfor %}
{{"Offline Devices:\n --"}} {{result.offline_devices|sort|unique|join('\n -- ')}}
Basically we just get iterate through desired integrations, get a list of devices in each, and then check if any [sensor,binary_sensor,switch] is offline.
Additionally, here is a ready to use blueprint for a similar result, but I used a very different technique in that one (searching by device_class (battery, switch)
So FWIW, part of the issue was the zha int he intregrations list… thank you for pointing that out. However that did not actually fix the issue but it was able to get me closer… I was able to get this working by removing the sort from the second for each
+ {% for device in integration_entities(integration) | map('device_id') | sort | unique | list %}
- {% for device in integration_entities(integration) | map('device_id') | unique | list %}
I ended up w/ the following:
{% set integrations=[ 'zwave_js','mqtt' ] %}
{% endif %}
{% endfor %}
{% endfor %}
{% endfor %}
