I feel like I am missing something simple here, since I am still new to using templates and creating cards on a dashboard. Basically, I have created an input_text helper, we’ll call it input_test
. I want to send the value of this helper to a service. Using the Services tab of the Developer Tools, I am able to do this successfully:
service: remote.send_command
entity_id: remote.my_remote
command: "{{states('input_text.input_test')}}"
With the above, the value of the helper is sent to the service, as desired.
However, I tried to put this service call into a button on my dashboard, and am not able to get the same result:
type: button
icon: mdi:send
tap_action:
action: call-service
service_data:
The only difference in the service call is the use of service_data
instead of data
, as that is what is required by tap-action.
However, when this button calls the service, instead of sending the helper value, it actually sends the template text:
{{states(‘input_text.input_test’)}}
Is what I want to do possible? It seems like it should be simple, but it isn’t working, hopefully, it is just a small error somewhere on my part. Any ideas?
