Template switch and yaml
Hi all
This weekend I have decided to tidy up my yaml and convert any old template sensors to the newer format, so far so good, I now have a template.yaml included.
In the template.yaml I have the following:
- sensors:
    sensor_1:
      friendly_name: "freindly name 1"
    sensor_2:
      friendly_name: "friendly name 2"
- binary_sensors:
    binary_sensor_1:
      friendly_name: "binary_sensor_1"
    binary_sensor_2:
      friendly_name: "binary_sensor_2"
I have removed all these entries from the original yaml and so far every thing is working as expected.
HOWEVER:
I have several template switches that I also waned to add to the same template.yaml but seem unable to no matter what formatting I try:
My current switch.yaml is formatted like this at present:
  switches:
    switch_1:
      friendly_name: 'template switch 1'
    switch_2:
      friendly_name: 'template switch 2'
I have tried several different ways to add these to template.yaml and no matter what I try I always end up with errors in the logs.
I assume something like this would work:
- sensors:
- binary_sensors:
- switches:
    switch_1:
But I get the following errors in the logs:
Invalid config for [template]: [switches] is an invalid option for [template]. Check: template->switches. (See /config/template.yaml, line 314).
(ERROR) config.py The entity definition format under template: differs from the platform configuration format.
Am I being stupid here or missing something obvious?
TIA
Rossk
According to the documentation, the new template definitions only applies to sensors, binary (on/off) sensors, buttons, numbers and selects. For Switches the old format still applies as far as I can tell.
Your a Gent…I suspected as much but failed to get a definitive answer from anywhere I was looking.
template:
- sensor:
  - name: ...
- binary_sensor:
  - name: ...
- number:
  - name: ...
- select:
  - name: ...
- button:
  - name: ...
switch:
  switches:
    xyz:
      friendly_name: ...
It’s going to take quite a bit of refactoring to get the other legacy templates into the new format as they have way more going on in them.
OK Thanks for the clarification, at least I can stop wasting my time now :slightly_smiling_face:
Best to just leave the switches.yaml as it is for the time being I guess.
FYI, the docs tell you what’s available in the new style if you know how to read the docs.
