Template switch: How to combine MQTT binary sensor and command line switch?
Hi there,
perhaps I missed something fundamental but I am not able to get a template switch showing the correct state of a LCD display. I try to combine a MQTT binary sensor and a command line switch. Both parts work fine on their own.
The MQTT binary sensor:
binary_sensor:
  - platform: mqtt
    state_topic: "tinkerforge/bricklet/lcd_20x4/ofH/backlight_on"
    payload_on: true
    payload_off: false
    value_template: '{{ value_json.backlight }}'
My switches (command line switch and template switch):
switch:
  - platform: command_line
    switches:
      tinkamosq:
        command_on: "mosquitto_pub -t tinkerforge/bricklet/lcd_20x4/ofH/backlight_on/set -m ''"
        command_off: "mosquitto_pub -t tinkerforge/bricklet/lcd_20x4/ofH/backlight_off/set -m ''"
    switches:
      lcdtemp:
        friendly_name: 'LCD Display'
        value_template: "{{ is_state('sensor.lcdstatus.state', 'on') }}"
        turn_on:
          service: switch.turn_on
          entity_id: switch.tinkamosq
        turn_off:
          service: switch.turn_off
Though I could turn the LCD display on and off the state of the LCD display shows always off.
I think that I do something wrong with the value_template of the template switch but I run out of ideas.
Perhaps someone could offer me a hint?
Thanks in advance,
topi
well, your lcdstatus is a binary_sensor, not a sensorā€¦ So first thing that comes to mind is that it should be
value_template: "{{ is_state('binary_sensor.lcdstatus.state', 'on') }}"
On top of that, I think you should not use a condition but jsut the template
value_template: "{{ states.binary_sensor.lcdstatus.state }}"
Also, from what I understand your command_line switch is just posting something into a MQTT topic, so you could use a mqtt_switch instead.
Thank you very much lambtho for the two hints (ā€œlcdstatus is a binary_sensor, not a sensorā€ and ā€œyou should not use a condition but just the templateā€). All is working now as intended :smile:
Please find the revised and working template switch configuration below:
switch:
            switches:
              tinkamosq:
            switches:
              lcdtemp:
                turn_on:
                turn_off:
Towards using a command_line switch instead of the mqtt_switch. Well, I tried but I have different command topics for turning the LCD on ā€œā€¦/lcd_20x4/ofH/backlight_on/setā€ and off ā€œlcd_20x4/ofH/backlight_off/setā€ which I am not able to fit in the mqtt_switch configuration which expects a different payload for turning the LCD on or off.
Thanks again for your help!
