Template switch with several targets
I want to create a template switch with several entities as target.
I tried the following code:
switch:
    switches:
      heizung_eg_heat:
        turn_on:
          service: switch.turn_on
            - entity_id: switch.heizung_eg_a8_relay1
            - entity_id: switch.heizung_eg_a8_relay2
        turn_off:
          service: switch.turn_off
            - entity_id: switch.heizung_eg_a8_relay3
            - entity_id: switch.heizung_eg_a8_relay4
            - entity_id: switch.heizung_eg_a8_relay5
            - entity_id: switch.heizung_eg_a8_relay6
But I get as error the following:
Logger: homeassistant.components.hassio
Source: components/hassio/__init__.py:586
Integration: Home Assistant Supervisor (documentation, issues)
First occurred: 11:36:08 (1 occurrences)
Last logged: 11:36:08
The system cannot restart because the configuration is not valid: Invalid config for [switch.template]: expected a dictionary for dictionary value @ data['switches']['heizung_eg_heat']['turn_off'][0]['target']. Got None expected a dictionary for dictionary value @ data['switches']['heizung_eg_heat']['turn_on'][0]['target']. Got None. (See ?, line ?).
Can someone tell me what is wrong? Or is that not possible and I can only do that via grouping the elements before into one entity ?
Thank you in advance.
Greets Karl
You only need a single entity_id key for each service, then list the entity IDs below that… Also, you need a value template:
switch:
    switches:
      heizung_eg_heat:
        value_template: |-
          {{ is_state('switch.heizung_eg_a8_relay1', 'on') and
          is_state('switch.heizung_eg_a8_relay2', 'on') }}
        turn_on:
            entity_id:
              - switch.heizung_eg_a8_relay1
              - switch.heizung_eg_a8_relay2
        turn_off:
            entity_id:
              - switch.heizung_eg_a8_relay3
              - switch.heizung_eg_a8_relay4
              - switch.heizung_eg_a8_relay5
              - switch.heizung_eg_a8_relay6
sometimes it is really easy - but now it is clear.
Thank you.
What for is the value template in the code ? I thought it is optional.
