I have recently discovered template switches and am rewriting a bunch of toggles/automations as switches and scripts to allow me to operate things from automations and from the UI if I need to.
I have some funny behaviour that I am trying to debug.
Let’s say I have a template switch switch.fun_mode, where the turn_on and turn_off functions are reasonably long scripts that take some time to execute.
Let’s now say that switch.fun_mode is already ON. If I call from another script the service:
does this execute the turn_on script again, or does it skip it because the switch state is on? If the former, is there some simple way to avoid an ON template switch from being turned on by another script?
Evidently no. I am asking a different question here, at least as far as I understand.
Test template switch:
test_switch:
friendly_name: Test Switch
icon_template: mdi:test-tube
value_template: "{{is_state('input_boolean.test_switch','on')}}"
unique_id: "834ut9j83y498v345345346456t"
turn_on:
- service: notify.persistent_notification
title: "Turn it on"
message: "Switch was turned on"
entity_id: input_boolean.test_switch
turn_off:
title: "Turn it off"
message: "Switch was turned off"
- service: input_boolean.turn_off
I can flip it by toggling in lovelace ON/OFF as much as I wish and it is working as I think it should – a sequence of on/off executions - on-off-on-off-on-off. But if I turn it on and then service call switch.turn_on from a script, it will run the on script again – on-on-on-on. I wasn’t expecting that.
I can think of wrapping the turn_on: script of the switch inside some choose condition which will check if is on already and skip it? As far as I can see, throwing it into an external script with a single execution mode isn’t going to help, since now the script is completing long before I re-trigger it.
