Template to convert entity C to °C - help please
I want to plot two temperatures on one graph and then probably go on from there to plot only the diffference between the two.
One is a standard °C entity.
The other is coming from Modbus (PMG_TEMP) where they only accept C as the unit of measurement.
I was thinking I could add a template something like below to convert C to °C but this does not seem to work - any ideas please:
      - name: "Turbine Temperature (°C)"
        unit_of_measurement: "°C"
        device_class: "temperature"
        state_class: "measurement"
        state: "{states('sensor.PMG_TEMP')}"
Create a template helper like this:
use
unit_of_measurement: ‘°C’
not „“
I now have this but is is not working:
        unit_of_measurement: '°C'
        state: "{{states('sensor.PMG_TEMP') | float(0)}}}"
One } too many ?
You don’t need a template sensor for this.
Use manual customization. e.g.
configuration.yaml
homeassistant:
  customize:
    sensor.pmg_temp:
Also the reason your template sensors are not working is because you are using capital letters in your entity id. Entity ids are always lower case.
Of course - thank you - now running - excellent
Thanks all!
Final yaml:
        state: "{{states('sensor.PMG_TEMP') | float(0)}}"
As I said, you do not need another entity for this. You can change the unit of the original sensor.
