I’m using a input_select to control the number of runs of my vacuum.
The service needs an int as an input.
I tried the following code, but obviously it does not work.
What am i doing wrong?
put your template in double quotes.
Thank you!
Using that
repeats: "{{ states('input_select.roborock_durchlaufe')}}"
in a card, its always corrected to
and that does not work.
Any ideas?
I’m using a mushroom-template-card
You can’t template in the frontend
Thanks for your quick reply. What’s the solution? instead of calling a service, i need to call a script that calls the service?
Or is there another way to use an entity_state as an input for the repeats?
A script is probably the best way
