I am trying to create a template that will prevent my motion detection camera alert from firing off when I enter zone.home in the past X minutes so I don’t get a “motion detected” alert when I get home, because if I don’t know that someone is at the door when I am at the door, something is terribly wrong. I already setup the following with my door sensor to prevent alerts for when I’m leaving the house:
I don’t know how/what to use to call “zone.home.enter = true” The specific device doesn’t matter (unless it does for template purposes). If any device linked to HA enters the zone, I don’t want to get a motion alert. Wife, kids, wife’s boyfriend. Whatever. I just don’t want a bunch of popups when someone I know (or at least someone with their phone) comes home.
I suppose I could do an if then delay or something, but a this seems perfect for a template in my mind. I’m just smart enough to do it.
Appreciate the help!
Edit: I think I figured it out, but I’m not sure if it’s the best way. Template is as follows:
{#check to see if front door sensor state has changed in 10 minutes#}
{{(as_timestamp(now()))-(as_timestamp(states.binary_sensor.front_door.last_changed)) < 600}}
{#check all device_tracker to see if any are home and they changed within the past 20 minutes#}
{%for state in states.device_tracker %}
{{ state.entity_id }} = {{ state.state }}
{% if is_state(state.entity_id, 'home') and ((as_timestamp(now()))-(as_timestamp(state.last_changed)) < 1200) %}
{{ true }}
{% endif %}
{% endfor %}
The problem I am having with this is that the state becomes “2” (or “x”) as more people come home. State “1” worked fine until my wife got home, then the condition was never met for her because she entered the zone it changed to “state zone.home=2”
Oh, I did not know that zone.home state had the number of person currently within the zone. I live alone, so… I assumed it was an on-off state… Makes sense
You could create a helper toggle switch and an automation that turns it off-on whenever someone enters the zone
alias: Enter zone
description: ""
mode: single
- platform: state
entity_id:
- person.person_1
to: home
- platform: state
entity_id:
- person.person_2
to: home
condition: []
- service: input_boolean.turn_off
data: {}
entity_id: input_boolean.zone_enter
data: {}
This will reset the “on” time of the helper switch every times someone enters the zone.
Then in your camera motion automation condition :
condition: or
conditions:
- condition: state
entity_id: zone.home
state: "0"
- condition: state
state: "on"
for:
minutes: 10
Thanks so much for the help and for all the effort you put in to it. I hadn’t considered helpers, but am glad you brought that up as an option. Good to know for future needs.
I actually stumbled across an old post by @Bluenight talking about namespaces and that did the trick! I couldn’t figure out how to create and use a variable, but namespace was the answer. I created a variable with a namespace that I could set to true if my conditions were met. Then I output the variable as the last line of the template so the automation executes or not based on the value in that variable. Since it loops through all of the device_trackers I can add more and wont have to mess with the automation.
{% set no_motion = namespace(home = false) %}
{% if is_state(state.entity_id, 'home') and ((as_timestamp(now()))-(as_timestamp(state.last_changed)) > 1200) %}
{% set no_motion.home = true %}
{% endif %}
{% endfor %}
{{ no_motion.home }}
