ygreq
(ygreq)
August 27, 2022, 9:55am
1
Hi folks!
Any idea how I can create a template that I can use in Lovelace so I can tick days of the week on and off? And based on the actual day of the week a binary sensor to turn on or off?
So in Lovelace if I tick Monday, Wednesday and Friday, on those specific days the binary sensor would turn on, otherwise off.
I found a few solutions of the forum but they don’t allow for presenting it on Lovelace.
Thank you so much!
tom_l
August 27, 2022, 10:21am
2
I currently use the custom button card .
- card_type: horizontal-stack
cards:
- entity: input_boolean.zone_3_mon
template: day_button
type: custom:button-card
- entity: input_boolean.zone_3_tue
- entity: input_boolean.zone_3_wed
- entity: input_boolean.zone_3_thu
- entity: input_boolean.zone_3_fri
- entity: input_boolean.zone_3_sat
- entity: input_boolean.zone_3_sun
template:
button_card_templates:
day_button:
color_type: icon
hold_action:
action: none
show_label: false
show_name: true
show_state: false
state:
- icon: mdi:checkbox-marked-circle
styles:
card:
- border: solid 1px var(--paper-item-icon-active-color)
- box-shadow: 0px 0px 10px 3px var(--paper-item-icon-active-color)
name:
- color: var(--primary-text-color)
value: 'on'
- icon: mdi:cancel
styles: null
value: 'off'
styles:
card:
- border-radius: 10px
- border: solid 1px var(--primary-color)
- box-shadow: none
- padding: 6px 0px
- margin: 0px 0px
- '--ha-card-background': rgba(0, 0, 0, 0)
grid:
- grid-template-areas: '"i" "n"'
- grid-template-rows: 33% auto
- grid-template-columns: auto
icon:
- width: 28px
name:
- justify-self: middle
- align-self: end
- font-size: 14px
- padding: 0px 0px
- color: var(--secondary-text-color)
tap_action:
action: toggle
However next month’s release introduces a schedule helper that I will be switching to.
ygreq
(ygreq)
August 27, 2022, 11:47am
3
May I ask where to put the code you shared? I’ve been going through the github and youtube to learn how to use the button-card, but still struggling.
I installed the button-card. But I am stuck at step 3 of the installation, I guess.
Add the configuration to your ui-lovelace.yaml
resources:
url: /hacsfiles/button-card/button-card.js
type: module
Where exactly should I put this code. I do not have a ui-lovelace.yaml.
Thank you so much!
tom_l
August 27, 2022, 12:00pm
4
If you install it with HACS you don’t have to worry about that, otherwise it is
Settings → Dashboards → ⋮ → Resources
ygreq
(ygreq)
August 27, 2022, 12:29pm
5
Then what are the actual steps I have to take in order to make your example work?
After creating the 7 input_booleans, I tried adding this to Lovelace:
cards:
- entity: input_boolean.monday
- entity: input_boolean.tuesday
- entity: input_boolean.wednesday
- entity: input_boolean.thursday
- entity: input_boolean.friday
- entity: input_boolean.saturday
- entity: input_boolean.sunday
But it gives me an error obviously as I did not add the button template. I tried adding the template in configuration.yaml, but that gives me an error as well. Should I put it somewhere else? What am I missing?
Thank you so much!
tom_l
August 27, 2022, 1:02pm
6
When you press the ⋮ icon to edit your dashboard press it again after that and select Raw configuration editor. Paste the template at the top of your raw dashboard YAML. Save and exit.
ygreq
(ygreq)
August 27, 2022, 1:16pm
7
I understand now. And it works, too. Thank you!!!
I do have a small issue, but maybe I can dibble in the template to make the icons smaller…
paulnel
(Paul)
December 16, 2022, 4:21am
8
Hallo, since latest update the color has gone wrong, pls will you comment on possible fix?
