Template to show (adjusted selection of) file name as title/message
HI,
please help me making a template to display a selected piece of string in the title / message of an automation notification…
this is the automation action:
  - service: notify.ios_iphone
    data_template:
      title: "Activity Speech"
      message: "Please listen" (change this into) {{ template for filename bit}}
        push:
          sound: >
            {% if is_state ('input_select.activity','Opstart') %} US-EN-Morgan-Freeman-Welcome-Home.wav
            {% elif is_state ('input_select.activity', 'Opstaan') %} US-EN-Morgan-Freeman-Good-Morning.wav
            {% elif is_state ('input_select.activity','Aan de slag') %} US-EN-Morgan-Freeman-Turning-On-The-Lights.wav
            {% elif is_state ('input_select.activity', 'Home theater') %} US-EN-Morgan-Freeman-Starting-Movie-Mode.wav
            {% elif is_state ('input_select.activity','Gym') %} US-EN-Morgan-Freeman-Motion-In-Game-Room.wav
            {% elif is_state ('input_select.activity', 'Selamat makan') %} US-EN-Morgan-Freeman-Motion-In-Kitchen.wav
            {% elif is_state ('input_select.activity', 'Uit huis') %} US-EN-Morgan-Freeman-Vacate-The-Premises.wav
            {% elif is_state ('input_select.activity', 'Naar bed') %} US-EN-Morgan-Freeman-Good-Night.wav
            {% endif %}
If activity ‘Aan de slag’ would be selected, I would want ‘Turning on the lights’ to appear in the message. So somehow it would need to:
  • select the correct file, (already done by this automation, working fine)
  • filter out the ‘US-EN-Morgan-Freeman-’ and ‘.wav’ bits,
  • change ‘Turning-On-The-Lights’ into Turning on the lights…
Could this be done? Need some of your better templating skills here…
Cheers,
Marius
off top of head I think you have to put the Full path in
something like
\local\Sound\US-EN-Morgan-Freeman-Welcome-Home.wav
local being the www folder
Sound being a subfolder under the www
im new at this to remember seeing somewhere the full path been used
no, thats not the issue, the files are built in the app. and already working i the above action.
next step is to have a template use that string part and transform it into the message …
thx
turning to you @anon43302295 as great templatist , would you know a solution for me, as i am almost there…:
{{states.input_select.speech_sound.state}} gives US-EN-Morgan-Freeman-Welcome-Home.wav
how can i use a template to have a message display Welcome Home.
all .wav files have the same naming convention so the template should cut of ‘US-En-Morgan-Freeman-’ form the beginning and ‘.wav’ at the end.
{{states.input_select.speech_sound.state[21:-4]}}
renders Welcome-Home, which is already fine.
next it should adjust Welcome-Home to Welcome Home
Can this be done? Please have a look?
thx,
Marius
Add |replace('-' , ' ') in to the end of the template?
yes… thank you!
{{states.input_select.speech_sound.state[21:-4]|replace('-' , ' ')}} gives Welcome Home
that seemed too simple, sorry…
now change the Home into home…
for the automation in my first post above i need a related template but i cant figure out what the name of the time is I need:
what template would i need to select the wav file? the data_template for the sound.
I’ve simply tried to enter the full template in the message field :slight_smile:
data_template:
          title: "Activity {{states.input_select.activity.state}} speech"
          message:
                {% elif is_state ('input_select.activity','Aan de slag') %} 'US-EN-Morgan-Freeman-Coworker-Is-Arriving.wav
                {% endif %}
which yields:
27
data_template:
          message:
                {% if is_state ('input_select.activity','Opstart') %} {{'US-EN-Morgan-Freeman-Welcome-Home.wav'[21:-4]|replace('-' , ' ')}}
                {% elif is_state ('input_select.activity', 'Opstaan') %} {{'US-EN-Morgan-Freeman-Good-Morning.wav'[21:-4]|replace('-' , ' ')}}
                {% elif is_state ('input_select.activity','Aan de slag') %} {{'US-EN-Morgan-Freeman-Coworker-Is-Arriving.wav'[21:-4]|replace('-' , ' ')}}
                {% elif is_state ('input_select.activity', 'Home theater') %} {{'US-EN-Morgan-Freeman-Starting-Movie-Mode.wav'[21:-4]|replace('-' , ' ')}}
                {% elif is_state ('input_select.activity','Gym') %} {{'US-EN-Morgan-Freeman-Motion-In-Game-Room.wav'[21:-4]|replace('-' , ' ')}}
                {% elif is_state ('input_select.activity', 'Selamat makan') %} {{'US-EN-Morgan-Freeman-Motion-In-Kitchen.wav'[21:-4]|replace('-' , ' ')}}
                {% elif is_state ('input_select.activity', 'Uit huis') %} {{'US-EN-Morgan-Freeman-Vacate-The-Premises.wav'[21:-4]|replace('-' , ' ')}}
                {% elif is_state ('input_select.activity', 'Naar bed') %} {{'US-EN-Morgan-Freeman-Good-Night.wav'[21:-4]|replace('-' , ' ')}}
                {% endif %}
yields the desired result…
but now I could have just created a new template with the text edited as desired … seems this should be possible in a more intelligent way…
Cheers,
Marius
