Apologies if this has ever been brought up before, but I couldn’t seem to find a related post.
I have a Razer Aether Monitor Bar light which is connected via Matter. This light has brightness, RGB, and color temp in one entity by default. I made a template in my configuration to split that into 2 separate entities, one for RGB and one for color temp. The color temp entity has brightness control but with this light connected VIA matter the RGB portion does not have separate brightness control.
My first attempt used this configuration:
light:
lights:
razer_aether_rgb:
friendly_name: "Razer Aether RGB"
value_template: "{{ is_state('light.razer_aether_monitor_bar', 'on') }}"
level_template: "{{ state_attr('light.razer_aether_monitor_bar', 'brightness') }}"
turn_on:
action: light.turn_on
entity_id: light.razer_aether_monitor_bar
rgb_color: [255, 255, 255] # White color
turn_off:
action: light.turn_off
set_rgb:
data_template:
rgb_color: "{{ rgb_color }}"
razer_aether_color_temp:
friendly_name: "Razer Aether Color Temperature"
turn_on:
color_temp: 250 # Color temperature
turn_off:
set_level:
data_template:
brightness: "{{ brightness }}"
set_temperature:
data_template:
color_temp: "{{ color_temp }}"
This worked for the color temp entity but the RGB entity kept throwing an error for “rgb_color” not being defined.
I’ve created a work around for now, I use a text helper instead and have an automation to change the origional entity rgb_color when the text helper changes. Does anyone know why the first method doesn’t work?
light:
lights:
razer_aether_rgb:
turn_on:
turn_off:
set_rgb:
data_template:
rgb_color: "{{states('input_text.razer_rgb_color')}}"
turn_on:
turn_off:
set_level:
data_template:
set_temperature:
data_template:
