So i’m not sure if this is just me, but if i have the Circadian switch on, my lights sometimes don’t fade off, or fade on (i think due to the color or brightness being set by Circadian)
So i want to fade up the lights to the color that Circadian current color, not fade them up and the have them transition to the current color.
I’ve been playing with the following script, but can’t seem to get it to work.
alias: 'Frontroom Lights On Slow'
sequence:
- service: switch.turn_off
entity_id: switch.circadian_lighting_ct_lights
entity_id: switch.circadian_lighting_rgb_lights
entity_id: switch.circadian_lighting_xy_lights
- service: light.turn_on
entity_id: light.kitchen_led
transition: 15
brightness: 120
rgb_color: "{{ states.sensor.circadian_values.attributes.rgb_color }}"
entity_id: light.led_uplighter
transition: 15
brightness: 120
entity_id: light.esp7_led
transition: 15
brightness: 120
- delay:
seconds: 20
- service: switch.turn_on
I’ve tried changing the " for ’ but still get nothing out. I can post logs if that helps, maybe i’ve had too much turkey tho…
