Template value should be a string for dictionary value
Hi
I’m struggling with the following automation / actionable notification, any help is appreciated!
The error is
Message malformed: template value should be a string for dictionary value @ data['action'][1]['then'][8]['data']
I don’t know what is causing this?
the code:
alias: test
description: ""
  - platform: numeric_state
    entity_id:
      - sensor.xiaomi_humidity
    for:
      hours: 0
      minutes: 15
      seconds: 0
    above: 55
  - variables:
      action_wtw_low: {{ "WTW_LOW" ~ context.id }}
      action_wtw_high: {{ "WTW_HIGH" ~ context.id }}
      action_do_nothing: {{ "DO_NOTHING" ~ context.id }}
  - if:
      - condition: trigger
        id:
          - "1"
    then:
      - service: notify.family
          title: WTW level.
          message: make a choice.
            actions:
              - action: {{action_wtw_low}}
                title: WTW low
              - action: {{action_wtw_high}}
                title: WTW high
              - action: {{action_do_nothing}}
                title: Do nothing
      - delay:
          hours: 0
          minutes: 0
          seconds: 30
          milliseconds: 0
      - wait_for_trigger:
          - platform: event
            event_type: mobile_app_notification_action
            event_data:
          - platform: event
            event_data:
          - platform: event
            event_data:
        timeout: "00:01:00"
      - choose:
          - conditions:
              - condition: template
                value_template: {{ wait.trigger.event.data.action in [ action_wtw_low ] }}
            sequence:
              - service: fan.set_preset_mode
                  preset_mode: low
                  entity_id: fan.wtw_ventilation
      - choose:
          - conditions:
                value_template: {{ wait.trigger.event.data.action in [ action_wtw_high ] }}
            sequence:
                  preset_mode: high
      - service: notify.familiy
          message: |
            {% if wait.trigger.event.data.action == action_wtw_low %}
              WTW to low
            {% elif wait.trigger.event.data.action == action_wtw_high %}
              WTW to high
            {% else %}
              Nothing is happened.
          title: Wtw
mode: single
I think it’s because of the template line
but when I try to use something like this, the error is the same unfortunately
value_template: '{{ wait.trigger.event.data.action == action_wtw_low }}'
Also when I remove the quotes.
You’re missing the end to your message if statement:
            {% else %}
            {% endif %}  {# <---- Add this #}
And yes, all single-line templates should be enclosed in quotes. See rule 1:
All curly brackets must be set in quotes if you want them to use as single lines:
  - variables:
      action_wtw_low: '{{ "WTW_LOW" ~ context.id }}'
      action_wtw_high: '{{ "WTW_HIGH" ~ context.id }}'
      action_do_nothing: '{{ "DO_NOTHING" ~ context.id }}'
        event_data:
          action: '{{action_wtw_low}}'
and so on
Alternative is multiline:
        event_data:
          action: >
            {{action_wtw_low}}
EDIT: 🥷 by Troon
