Hey there!
I have problem with this code and do not know what to add and where:
sensors:
hassio_drifttid:
friendly_name: 'Hassio Drifttid'
value_template: >-
{%- set word_for_and = 'och' %}
{%- set up_time = as_timestamp(now())-as_timestamp(states('sensor.uptime')) %}
{%- macro phrase(name, plural_name, divisor, mod=None) %}
{%- set value = ((up_time // divisor) % (mod if mod else divisor)) | int %}
{%- set name = plural_name if value > 1 else name %}
{{- '{} {}'.format(value, name) if value | int > 0 else '' }}
{%- endmacro %}
{%- set values = [
phrase('dag', 'dagar', 60*60*24, 7),
phrase('timme', 'timmar', 60*60, 24),
phrase('min', 'min', 60)
] | select('!=','') | list %}
{{ values[:-1] | join(', ') ~ ' ' ~ word_for_and ~ ' ' ~ values[-1] if values | length > 1 else values | first }}
Warning:
2021-04-21 19:26:15 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: No first item, sequence was empty. when rendering '{%- set word_for_and = 'och' %} {%- set up_time = as_timestamp(now())-as_timestamp(states('sensor.uptime')) %}
{%- endmacro %}
{%- set values = [
{{ values[:-1] | join(', ') ~ ' ' ~ word_for_and ~ ' ' ~ values[-1] if values | length > 1 else values | first }}'
What do I ADD and where?
Thanks!
