Hi , i keep getting this warning in my log (it’s not the i didn’t bother, or wanted to see what’s happening after 2022.1) i am on latest-N greatest, just been Lazy lately. … and it’s still running
Template warning: 'int' got invalid input 'unknown' when rendering template '{% set s = states('sensor.rt_ax68u_d680_uptime') | int %}{{ '%02d:%02d:%02d' % ((s/86400)|int,((s%86400) / 3600)|int,(s%3600) / 60) }}' but no default was specified. Currently 'int' will return '0', however this template will fail to render in Home Assistant core 2022.1
- type: custom:template-entity-row
active: true
icon: mdi:router-network
state: >
It’s still running, but i don’t know how/what i should write it instead … i just wanted it to show days/hours/minutes … if anyone can solve the mystery, or even give me hint how i can make it better, like txt above or so, i would appreciate it … it is a littler tricky to “combine” a custom:template-entity-row , what i have tried(doesn’t “fit” into custom:multiple-entity-row i.e
PS: i just noticed the “seamlessly syntax error” …the extra ( in-front of days | hours … just tried to remove them or/and add behind, several places … guess i just kept it like this, after i got it running
Change all instances of int to int(0) in order to provide a default value of 0 in case the filter cannot convert the supplied value. It doesn’t have to be 0 and you can specify whatever default value you want.
The root problem is that the value of sensor.rt_ax68u_d680_uptime was unknown. The int filter cannot convert that to an integer so it reports a default value (which you must specify).
weird is, it’s trowing more now! , but still "see it as int, and not int(0), or int(3)
Template warning: 'int' got invalid input 'unknown' when rendering template '{% set s = states('sensor.rt_ax68u_d680_uptime') | int %}{{ '%02d:%02d:%02d' % ((s/86400)|int(0),((s%86400) / 3600)|int(0),(s%3600) / 60) }}' but no default was specified. Currently 'int' will return '0', however this template will fail to render in Home Assistant core 2022.1
18:28:14 – (WARNING) helpers/template.py - message first occurred at 18:28:14 and shows up 14 times
ok, i did try that first time, both clear cache and restart(not reboot) , but initially without anything after int, it’s throws less, if i put int(3) it throws same warning 18 times … in any case, it’s only during a restart it’s throwing this “warning” … and as i said above, im on latest and greatest … so the warning that it wont “render” after 2022.1 don’t seems to apply either … maybe ive done/missed some other things in my syntax, but i’ve tried alot, removing spaces, brackets etc …
Template warning: ‘int’ got invalid input ‘unknown’ when rendering template ‘{% set s = states(‘sensor.rt_ax68u_d680_uptime’) | int %}{{ ‘%02d:%02d:%02d’ % ((s/86400)| int(0),((s%86400) / 3600)|int(0),(s%3600) / 60) }}’ but no default was specified. Currently ‘int’ will return ‘0’, however this template will fail to render in Home Assistant core 2022.1
18:36:44 – (WARNING) helpers/template.py - message first occurred at 18:36:44 and shows up 18 times
2022-02-16 18:36:44 WARNING (MainThread) [homeassistant.helpers.template] Template warning: ‘int’ got invalid input ‘unknown’ when rendering template ‘{% set s = states(‘sensor.rt_ax68u_d680_uptime’)| int %}{{ ‘%02d:%02d:%02d’ % ((s/86400)|int(3),((s%86400) / 3600)|int,(s%3600) / 60) }}’ but no default was specified. Currently ‘int’ will return ‘0’, however this template will fail to render in Home Assistant core 2022.1
2022-02-16 18:36:44 WARNING (MainThread) [homeassistant.helpers.template] Template warning: ‘int’ got invalid input ‘unknown’ when rendering template ‘{% set s = states(‘sensor.rt_ax68u_d680_uptime’)| int %}{{ ‘%02d:%02d:%02d’ % ((s/86400)|int(3),((s%86400) / 3600)|int(3),(s%3600) / 60) }}’ but no default was specified. Currently ‘int’ will return ‘0’, however this template will fail to render in Home Assistant core 2022.1
See my “root problem” explanation above. Which integration is used for sensor.rt_ax68u_d680_uptime? Whatever it is, it’s not supplying the sensor with a value at startup (at least not soon enough anyway).
FWIW, the last warning message you posted doesn’t contain int with a default value. Whatever changes you’re making don’t appear to “stick”.
If you have a template in template editor that uses int or as_timestamp or any of those functions that need a default value, then there won’t be an error in template editor, but in the logs you get an error that you used a “incorrect” template in templates tool.
I get an error for something that I have not used in a long time.
Probably it’s on some device since each device has their own template editor.
ok, i got what you mean … i just did try to remove/reverse back to my initial template … int … without (0) … then it complains about a missing…end bracket )
… but i have no clue where i should put that, or whether where i might have 1 start … i did wonder over the 2 “start” bracket before days | hours … as they dont seems to have an "end ) "
I meant some computer/mobile.
If I add a template on one computer, it will not be visible on the other computer even with the same account. I believe I have once tested a template and it’s still “open” somewhere.
Thanks Guys, wont tag you … syntax fixed by 123, petro and in specific Hellis81 did get me thinking … i disconnected my(this) work-laptop(where i did all the mess), then checked on the server ( error messages there in logs(obviously)) … but after restart (under server-controls) on the server, i got “clean” start-up log …
… so i only sitting here with my thoughts , should i restart this (work-laptop) obviously i didn’t help clearing browser, or will i as Hellis have to live with this, error/warning in the logs, when restarting from this laptop ? … i guess time will tell … so far i consider this as solved, thx again
thou i see my (this) template on all 3 laptops, and a PC and phone, just by refreshing browser ( thou this time i hadn’t touched the server during these “changes”
PS … don’t ask me why all “commends” is tagged as “solution” … there is alot i don’t understand, but i did learn some more today … thou i did thought it was only the “view” design setup, that wouldn’t change, if i didn’t do a refresh on other devices,
… i use UI to initially create my “views” so they are ui-controlled, not YAML
ok, yes i’ve noticed that i can choose “default views” for different devices, but i try to keep my “responsive”, and so far, i don’t have any “Wall Dashboards” or any ipad etc, that would benefit from a Specific “View” … only been around here since October 21
