using a first config like:
condition_template: >
{{states('sensor.br_condition')}}
temperature_template: >
{{states('sensor.weatherbit_apparent_temperature')|float}}
humidity_template: >
{{states('sensor.weatherbit_humidity')|float}}
forecast_template: >
{{state_attr('weather.buienradar','forecast')}}
pressure_template: >
{{states('sensor.luftdaten_37248_pressure')}}
wind_speed_template: >
{{states('sensor.openweathermap_wind_speed')|float}}
all of which templates are correct and display their values in the template editor, this error is throes in the log
Logger: homeassistant.helpers.event
Source: components/weather/__init__.py:181
First occurred: 1:51:43 PM (2 occurrences)
Last logged: 1:51:46 PM
Error while processing state change for sensor.openweathermap_wind_speed
Error while processing state change for sensor.luftdaten_37248_pressure
File "/usr/src/homeassistant/homeassistant/helpers/event.py", line 280, in _async_state_change_dispatcher
hass.async_run_hass_job(job, event)
File "/usr/src/homeassistant/homeassistant/core.py", line 435, in async_run_hass_job
hassjob.target(*args)
File "/usr/src/homeassistant/homeassistant/helpers/event.py", line 1005, in _refresh
self.hass.async_run_hass_job(self._job, event, updates)
File "/usr/src/homeassistant/homeassistant/components/template/template_entity.py", line 251, in _handle_results
self.async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 295, in async_write_ha_state
self._async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 321, in _async_write_ha_state
attr.update(self.state_attributes or {})
File "/usr/src/homeassistant/homeassistant/components/weather/__init__.py", line 181, in state_attributes
forecast_entry = dict(forecast_entry)
ValueError: dictionary update sequence element #0 has length 1; 2 is required
while the 2 mentioned offenders sensor.openweathermap_wind_speed
and sensor.luftdaten_37248_pressure are correct:
what could be wrong here?
por is it the forecast template, taking that out check the config valid, as does rewriting it like
{{states.weather.buienradar.attibutes.forecast}}
btw, the weather integration is then created, and without any forecast…
using:
forecast_template: '{{states.weather.buienradar.attributes.forecast}}'
doesn’t help, the integration isn’t created in that case
thanks for having a look
