I can’t seem to get the Template Weather Provider to work, specifically importing a weather provider to provide the hourly and daily forecasts. I’m trying to combine an Ecowitt weather station with Tomorrow.io’s hourly and daily forecasts. Here are the templates that I’m using:
template:
- trigger:
- platform: time_pattern
hours: /1
- service: weather.get_forecast
type: daily
entity_id: weather.tomorrow_io_home_daily
response_variable: daily
- name: Daily Forecast
unique_id: weather_forecast_daily
state: "{{ now().isoformat() }}"
attributes:
forecast: "{{ daily.forecast }}"
- trigger:
hours: /1
type: hourly
response_variable: hourly
- name: Hourly Forecast
unique_id: weather_forecast_hourly
attributes:
forecast: "{{ hourly.forecast }}"
weather:
condition_template: "{{states('weather.tomorrow_io_home_daily')}}"
temperature_template: "{{states('sensor.gw2000b_v2_1_8_outdoor_temperature') | float }}"
dew_point_template: "{{ states('sensor.gw2000b_v2_1_8_dewpoint') | float }}"
apparent_temperature_template: "{{ states('sensor.gw2000b_v2_1_8_feels_like_temperature') | float }}"
temperature_unit: "°F"
humidity_template: "{{states('sensor.gw2000b_v2_1_8_humidity') | float }}"
pressure_template: "{{states('sensor.gw2000b_v2_1_8_absolute_pressure') | float }}"
pressure_unit: "inHg"
wind_speed_template: "{{states('sensor.gw2000b_v2_1_8_wind_speed') | float }}"
wind_gust_speed_template: "{{ states('sensor.gw2000b_v2_1_8_wind_gust') | float }}"
wind_speed_unit: "mph"
wind_bearing_template: "{{states('sensor.gw2000b_v2_1_8_wind_direction') | float }}"
ozone_template: "{{states('sensor.current_ozone_level') | float }}"
visibility_template: "{{state_attr('weather.tomorrow_io_home_daily','visibility') | float }}"
visibility_unit: "mi"
forecast_daily_template: "{{ state_attr('weather_forecast_daily', 'forecast') }}"
forecast_hourly_template: "{{ state_attr('weather_forecast_hourly', 'forecast') }}"
precipitation_unit: "in"
Template sensor properly report the hourly and daily forecasts. However, the combine platform only reports information from the actual sensors and doesn’t include anything from the template sensors. When I try to call my new weather provider with weather.get_forecast, the response is forecast: [ ].
Thanks for your help.
