i would like to make a template which shows the lowest outside temperature (measured by my weather station) reached today. asked ChatGpt for help but that did not work… hope somebode can help me out.
Don’t use a template sensor use this:
Despite its name it also reports max. and min. as attributes.
And unlike the core home assistant Statistics sensor it can report the minimum for a time period of a calendar day instead of the last 24 hours from now.
sensors.yaml
- platform: average
name: 'Average Temperature'
start: "{{ today_at('00:00') }}"
end: "{{ now() }}"
entities:
- sensor.your_temperature_sensor_here
If you want to break out the attribute into its own sensor you will need a template sensor. However it can be used and displayed most places without doing that.
What do you want it for?
Thanks Tom_I,
ı will try this.
will use it to check the minimum temperature my plants and chicken faced. off course i can also ”see” it in the graph of the outside temp but this will be eassier.
