I’m trying to create an automation that changes the color of a light based on the air quality index. I’m stuck on a yaml syntax issue where I can’t include an array/collection in the block scaler style.
This is probably a pretty simple thing, but I’m not getting anywhere with my searching…
If I just break it down to the simplest bit of code, what I want to do is this:
color_rgb: >
[0, 0, 255]
I think that doesn’t work because yaml is interpreting it as a string “[0, 0, 255]” rather than a collection. So I think I’m looking for a way to indicate that it is not a string, but is a collection. But maybe this has more to do with jinja templating? Help is greatly appreciated!
Thanks! That did the trick. My older Hue bulb has pretty bad colors, so I’d like to have the ability to tweak the colors and stuck with the rgb color values.
Step 1: Don’t mess up the name of the color attribute - it’s rgb_color NOT color_rgb. That definitely didn’t help with my troubleshooting…(obviously my own fault not yours)
Step 2: Templating each part of the array wasn’t too bad. Here’s the code that works:
- data_template:
rgb_color:
{% if states('sensor.chinese_air_quality_index') | int < 50 %} 168
{% elif states('sensor.chinese_air_quality_index') | int < 100 %} 253
{% elif states('sensor.chinese_air_quality_index') | int < 150 %} 254
{% elif states('sensor.chinese_air_quality_index') | int < 200 %} 254
{% elif states('sensor.chinese_air_quality_index') | int < 300 %} 169
{%else %} 168 {% endif %}
{% if states('sensor.chinese_air_quality_index') | int < 50 %} 224
{% elif states('sensor.chinese_air_quality_index') | int < 100 %} 215
{% elif states('sensor.chinese_air_quality_index') | int < 150 %} 155
{% elif states('sensor.chinese_air_quality_index') | int < 200 %} 106
{% elif states('sensor.chinese_air_quality_index') | int < 300 %} 122
{%else %} 115 {% endif %}
{% if states('sensor.chinese_air_quality_index') | int < 50 %} 95
{% elif states('sensor.chinese_air_quality_index') | int < 100 %} 75
{% elif states('sensor.chinese_air_quality_index') | int < 150 %} 87
{% elif states('sensor.chinese_air_quality_index') | int < 200 %} 105
{% elif states('sensor.chinese_air_quality_index') | int < 300 %} 188
{%else %} 131 {% endif %}
service: light.turn_on
entity_id: light.officehuebulb
- data_template:
rgb_color:
{% set i = (states('sensor.chinese_air_quality_index') | int) // 50 %}
{% set r = [168, 253, 254, 254, 169, 169] %}
{{ r[i] if i < 6 else 168 }}
{% set g = [224, 215, 155, 106, 122, 122] %}
{{ g[i] if i < 6 else 115 }}
{% set b = [95, 75, 87, 105, 188, 188] %}
{{ b[i] if i < 6 else 131 }}
It leverages the fact you use every additional increment of 50 (air quality index) to be represented by another color. So we use integer division to divide the air quality index by 50. The result is used to select an item from the list.
