I’m trying to write a very simple template in which I want to give an output depending on the value of a sensor (positive or negative).
I’m a newcomer and so far I’ve been able to write even simpler templates doing operations with sensors.
As soon as I include the if statement, I get the weirdest errors which I’m not able to interpret, not to say to fix!
the code works perfectly well in the Developer tools → Template Editor (as per below)
{% if states('sensor.sh_3em_linea_principale_total_power') | float(0) < 0.0 -%}
state: {{ states('sensor.mpz_total_power_consumption') }}
{%- else -%}
state: {{ states('sensor.verso_giusto_power') }}
{%- endif %}
returning:
Result type: string
state: 197.19
This template listens for the following state changed events:
* **Entity**: sensor.mpz_total_power_consumption
* **Entity**: sensor.sh_3em_linea_principale_total_power
After inserting the code in the template.yaml file, with the proper formatting, I can’t restart HA.
By proper formatting, from what the very little I understood, I get that the language is to be modified slightly because the template file is parsed as YAML. Instead, the {{…}}’s are parsed/evaluated as Jinja templates. The syntax in either cases is not very clear to me, didn’t find a place with a clear enough explanation for a neophyte.
The best I could find about adapting code from template editor to template.yaml was this (Important template rules). Any better and more complete suggestion?
One of the errors I get when trying to reload, related to the code block below, is the following:
Cannot quick reload all YAML configurations because the configuration is not valid: Error loading /config/configuration.yaml: while scanning for the next token found character ‘%’ that cannot start any token in “/config/templates.yaml”, line 71, column 6
The code is the following:
- sensor:
## Total effective power
## this template is working properly
- name: MPz Total Power Consumption
state: "{{ states('sensor.piano_1_power') | float(0) + states('sensor.piano_t_power') | float(0) + states('sensor.locale_t_power') | float(0) + states('sensor.loctecnenergia_power') | float(0) }}"
unit_of_measurement: 'W'
## Self consumption power
## this template returns errors when saved into templates.yaml
- name: MPz Selfconsumption
{% if states('sensor.sh_3em_linea_principale_total_power') | float(0) < 0.0 | float(0) %}
state: "{{ states('sensor.MPz_Total_Power_Consumption') | float(0) }}"
{% else %}
state: "{{ states('sensor.verso_giusto_power') | float(0) }}"
{% endif %}
Line 71 is the following (in the above code):
I’ve looked everywhere for help, both in this blog (for instance in this post) and elsewhere to no avail.
I’ve experimented with
- rewriting the code from scratch several times
- Indentations, spaces
- “…”, ‘…’ before&after the {%…%}
- much simpler code like the following (which again does work in the template editor and fails in the templates.yaml with the same error):
{% if 1.0 < 0.0 %}
state: "{{ 1.0 }}"
{% else %}
state: "{{ -1.0 }}"
{% endif %}
- I’ve tried to write the code both with Studio Code Server from inside HA and externally with xCode
With the former (Studio Code) I get errors inside Studio as well, more than one and that again I don’t understand, I provide both the code and a screenshot
## Self Consumption power
- name: MPz Self Consumption
{% else %}
{% endif %}
which looks totally the same, and the followings are the errors shown:
My system is the following (working from a MacBook Pro 16" M1 Max):
Home Assistant 2023.10.3
Supervisor 2023.10.0
Operating System 11.0
Frontend 20231005.0 - latest
on a Raspberry Pi 4-64
Summarising… i’m lost and I thank you all in advance for any help.
Forgive any language and programming mistake, as I said, i’m a newby and I tried all the best myself for several days (and nights)
