I’m getting error messages from the template engine.
The template is used to find out if the garage door is open/close.
The template reads the angle of the door as a numeric value.
The automation that uses this sensor is working fine. The template gives a good result in the template editor. but the logs are keeping giving errors.
What am I missing here?
Logger: homeassistant.components.template.template_entity
Source: components/template/template_entity.py:173
Integration: Template (documentation, issues)
First occurred: 11:22:36 AM (9 occurrences)
Last logged: 12:36:16 PM
TemplateError('ValueError: Template error: int got invalid input 'unknown' when rendering template '{% set positie = states('sensor.zb_kanteldeur_rechts_angle_y')| int %} {% if positie | int >= -50 %} mdi:garage-open-variant {% elif positie | int < -50 %} mdi:garage-variant {% endif %}' but no default was specified') while processing template 'Template("{% set positie = states('sensor.zb_kanteldeur_rechts_angle_y')| int %} {% if positie | int >= -50 %} mdi:garage-open-variant {% elif positie | int < -50 %} mdi:garage-variant {% endif %}")' for attribute '_attr_icon' in entity 'sensor.kanteldeur_positie_fiat'
TemplateError('ValueError: Template error: float got invalid input 'unknown' when rendering template '{% set positie = states('sensor.zb_kanteldeur_links_angle_y') %} {% if positie | float >= -30 %} Open {% elif positie | float < -30 %} Closed {% endif %}' but no default was specified') while processing template 'Template("{% set positie = states('sensor.zb_kanteldeur_links_angle_y') %} {% if positie | float >= -30 %} Open {% elif positie | float < -30 %} Closed {% endif %}")' for attribute '_attr_native_value' in entity 'sensor.kanteldeur_positie_tesla'
TemplateError('ValueError: Template error: float got invalid input 'unknown' when rendering template '{% set positie = states('sensor.zb_kanteldeur_links_angle_y') %} {% if positie | float >= -30 %} mdi:garage-open-variant {% elif positie | float < -30 %} mdi:garage-variant {% endif %}' but no default was specified') while processing template 'Template("{% set positie = states('sensor.zb_kanteldeur_links_angle_y') %} {% if positie | float >= -30 %} mdi:garage-open-variant {% elif positie | float < -30 %} mdi:garage-variant {% endif %}")' for attribute '_attr_icon' in entity 'sensor.kanteldeur_positie_tesla'
TemplateError('ValueError: Template error: float got invalid input 'unknown' when rendering template '{{ states('sensor.voerhok_th_am2301_temperature')|float < 0 }}' but no default was specified') while processing template 'Template("{{ states('sensor.voerhok_th_am2301_temperature')|float < 0 }}")' for attribute '_state' in entity 'binary_sensor.voerhok_onder_nul'
TemplateError('ValueError: Template error: float got invalid input 'unavailable' when rendering template '{{ states('sensor.voerhok_th_am2301_temperature')|float < 0 }}' but no default was specified') while processing template 'Template("{{ states('sensor.voerhok_th_am2301_temperature')|float < 0 }}")' for attribute '_state' in entity 'binary_sensor.voerhok_onder_nul'
This is my template config
- sensors:
kanteldeur_positie:
friendly_name: Kanteldeur positie
value_template: >-
{% set positie = states('sensor.zb_kanteldeur_angle_y')| int %}
{% if positie | int <= 70 %}
Open
{% elif positie | int > 70 %}
Closed
{% endif %}
icon_template: >-
mdi:garage-variant
{% endif %}
# de sensor van autogarage Panda heeft sensor R (dus van binnenuit gezien)
kanteldeur_positie_fiat:
friendly_name: Kanteldeur positie Fiat
value_template: >-
Open
Closed
{% endif %}
icon_template: >-
mdi:garage-variant
{% endif %}
