Without the unique_id there doesn't seem to be a way to NOT trigger when templates are reloaded. (With the unique_id you can look for the "unavailable" state.)
The events have to_state: null and from_state: null.
I tried the usual suspects "unknown", "null", "None", "unavailable" and even the "~' yaml trick.
Is there another method I'm not seeing? I didn't see this mentioned in the documentation.
Or, why not just use a Input button helper? A Template Button's main purpose is that it combines features of an Input Button and an automation. If you aren't utilizing the "automation" portion represented by the press action sequence, then the Template Button offers no benefit over the Input Button.
Because the question was if there's no unique_id is there a way to block the trigger. That's all. Just curious if there was a reason and if it was a documented state.
And for the questions you asked:
Template buttons have an availability config option which can be also checked by uix.
I'm not using automations, I'm using triggered templates.
A bit off topic, but the button is triggering (yes, by a state event) a template sensor that is updating its state and attributes, which needs to be done in a template sensor.
The trigger is a dictionary and the key is there, just no object attached. And the value is thus NoneType.
It's just a side effect of not setting unique_id, which results in the typical use of the not_to and not_from tests not working on the trigger during a reload because, well, there's no attached State object to test the state of.
Sure, one could test this is a condition, if that's what you are implying. But the not_to and not_from are the typical way of blocking triggers.
I was just reloading templates frequently and kept seeing (unrelated) logs for a button push, an edge case I was curious about.
template buttons do not update from the template integration FYI. There is no "templates" that cause buttons to resolve a new state. This is normal button entity behavior.
Interesting about the template buttons, but this isn't specific to buttons.
Again, only happens on YAML reload and can simply add a unique_id, so not a big issue at all. unique_id is optional, but there's this difference in behavior.
But to make it clear:
The point is if you do not set a unique_id then when reloading you get a null for the state object (it's triggered twice -- unloading and loading).
So, with this sensor (no unique_id)
- sensor:
- name: Test Standard Template
default_entity_id: sensor.std_template
state: "{{ states('input_text.some_input_text') }}"
The trigger will look like the following. Note how the from_state is missing an object.
idx: '0'
alias: null
platform: state
from_state: null
to_state:
state: Some text
Without a from_state object you cannot use not_from: unavailable to block that trigger as there's no state object to inspect. (I'm a bit surprised there's no error in the logs.)
There's two events, so the other event is to_state: null so checking not_to: unavailable fails as well.
Once there's an unique_id both state objects are there, so testing for unavailable works.
idx: '0'
alias: null
platform: state
entity_id: sensor.std_template_with_id
from_state:
state: unavailable
attributes:
restored: true
friendly_name: Test Standard Template With ID
supported_features: 0
last_changed: '2026-06-30T17:13:01.277387+00:00'
last_reported: '2026-06-30T17:13:01.277387+00:00'
last_updated: '2026-06-30T17:13:01.277387+00:00'
context:
parent_id: null
user_id: null
to_state:
state: Some text
