Your assumption is correct. I was on a meetup in the summer where Paulus was a guest speaker and he confirmed at the moment Home Assistant only allows real time data and there is no feature to backdate readings yet.
Thanks for the info. I will continue to use the great solution @oneofthemany has created and wait for the capability to get better.
Thanks oneofthemany this has all been really useful and I have finally found time to start setting up my config.
I have one small issue/question.
I donāt seem to be able to get 48 readings for electricity until two days later. Can you think of a reason for this? Iām suspecting it must be some quirk it the data collection for my meter because this:
https://api.octopus.energy/v1/electricity-meter-points/{mpan}/meters/{serial}/consumption/?period_from=2021-11-13T00:23:30&period_to=2021-11-13T23:59:59
returns this (the date/time now is 2021-11-14T09:00:00
{"count":0,"next":null,"previous":null,"results":[]}
But this:
https://api.octopus.energy/v1/electricity-meter-points/{mpan}/meters/{serial}/consumption/?period_from=2021-11-12T23:30:00&period_to=2021-11-12T23:59:59
returns this:
{"count":1,"next":null,"previous":null,"results":[{"consumption":0.099,"interval_start":"2021-11-12T23:30:00","interval_end":"2021-11-13T00:00:00"}]}
So apparently there is no reading for that last half an hour (unless I wait another 24 hours).
Thanks for any insightā¦
And as an aside, I am far from an expert when it comes to date time formats and as you omitted them Iām probably wrong but I just thought Iād check; shouldnāt the datetimes have a āZā at the end to cater for BST? (i.e. 2021-11-14T09:00:00Z) - itās six months until I can check for myself!!
yes it will take 48hrs to pull the data from the API and then you should be OK - you have to be patient
Ahā¦ ok. Thanks.
But doesnāt that then mean the data is for the day before yesterday?
In which case shouldnāt the rest sensors be - timedelta(days = 2)
apologies
it has to take 48 readings which can take in excess of 24hrs
sorry for the confusion
How are you getting from this stage of having a well formed API call with some results, to graphs? If I curl the URL my code generates at the command line I can see results. The same URL in my restul sensor implementation I get a key definiton error because results
does not exist.
read from here in this post:
ah ok - well that is what I have been using but without getting any results returned. Having read about the potential 24+ hour delay in posts above I waited for a week but the gas or electricity sensor still werenāt returning any data.
I copied the resulting API URL from the code from this post and curlād it (with appropriate auth) to get no results returned. If I changed the date range to the day before I get results so the command and URL in itself are correct, just the date range isnāt. Am I doing something stupid?
Most likely you have the MPAN and Meter serial numbers wrongā¦ That was a mistake I made for a while.
Check out the Octopus developer portal to confirm you are using the right ones:
Also there are a couple of examples you can use there to test you are seeing correct data (without the date parameters used by these templates)
Yeah this is totally possible!
@velkrosmaak : could you push some output data based on your config if the above didnāt solve your issue and we can see about getting you sorted if youāre still struggling to get results
Hi
Thanks @oneofthemany for the solution.
Is there also a 24/48hr delay in selecting Consumed Energy (kWh) on the Energy Dashboard? Iām not seeing any options.
I had to do a tweak to my yaml this morning (API to Base64) and now are seeing data for all the entities created apart from Electricity Cost, Gas Cost and Go Current Rate. Iād have thought once data is pulled through on all the consumption entities though theyād be ready to choose from?
yeah the Base 64 seems to be missed by quite a few people
the costs only show up once you have enough data - this can take up to 2 days (highly dependent on the time you initiated your first API call
I was hopeful this was the case, but alas I annoyingly did have them the right way around.
@oneofthemany this was just the script copied from your post unedited apart from my account details and API key. The sensors for electricity/gas readings donāt actually appear in HASS either.
I modified both scripts like this, as I was getting results when curling yesterdayās dates via the API.
- platform: rest
name: Gas consumption
resource_template: >-
{% set mpan = '00000' %}
{% set serial = 'E00000' %}
{% set date = as_timestamp(now() - timedelta(days = 1))|timestamp_custom('%Y-%m-%d') + 'T00:00:00' %}
{% set datefrom = as_timestamp(now() - timedelta(days = 3))|timestamp_custom('%Y-%m-%d') + 'T00:00:00' %}
https://api.octopus.energy/v1/gas-meter-points/{{ mpan }}/meters/{{ serial }}/consumption/?period_from={{ datefrom }}&period_to={{ date }}
headers:
Authorization: Basic <base 64 encoded api key>
json_attributes:
- "results"
value_template: "{{ value_json.results|sum(attribute='consumption')|round(3) }}"
unit_of_measurement: 'kWh'
device_class: energy
If I use the curl example on the Octopus API page right now (0100 on 18/12/2012) I get results up until 2021-12-17T00:00:00Z. I donāt get that in HASS though so that I can graph yesterdays readings.
Yeah costs are still not in there yet, but strangely the off peak cost is? Iām more interested in consumption though so that is no big deal.
Iām seeing a lot of log errors relating to REST sensors in the logs, however the kWh is pulling through correctly to the entities. I just canāt select any of the consumption entities when setting up the energy dashboard so something is not quite right. Iāve created my own graphs using the data for now, just canāt understand why the Energy section canāt see them?
For now too I followed a link to convert REST to a template sensor from when REST wasnāt supported, so i have an entity called āElectricity Consumption NEWā which can be picked up by the energy dashboard. Iāve only done this for the main Elec and Gas andā¦i could do it for all of the different consumptionsā¦however iād like to clear the errors in the log but iām not technical enough to know what they mean.
Yes Iāve followed it to the tee, apart from the secrets base64 which I edited later.
All sensors from the customise.yaml are showing in Dev Tools with a value next to them, theyāre just not there in the Energy Dashboard consumption dropdown for selection. As soon as I make a template sensor from them that is selectable. Iāve made a card for all the ones created and apart from the two costs as mentioned earlier all others are populated.
Iām on 2021.12.1
customise or customize?
customize.yaml. Was typing on mobile and auto corrected.
without seeing your config i cant offer any further comments
please drop what you have done in the chat and perhaps we can identify the issues you seem to be having
