hadov
January 24, 2021, 4:43pm
1
Hi all,
This is my first post here and I’m excited to be part of this community.
I’ve done a bunch of simple automation but hit the wall when trying to achieve volume up and unmute in one automation.
- service: media_player.volume_up
entity_id: media_player.snapcast_client_bedroom
data: {}
- service: media_player.volume_mute
is_volume_muted: false
I trigger this when pressing a button and it works fine except for the fact that it’ll always increase the volume. I’m trying to make it to only unmute in case it’s muted and increase the volume otherwise.
I’ve tried so many configurations but none got me there.
This is an example of one of those failed attempts:
service_template: >
{% if (state_attr('media_player.snapcast_client_bedroom', 'is_volume_muted')) -%}
media_player.mute
{%- else -%}
{%- endif -%}
I think the service part is working, and it’s indeed choosing media_player.mute
if it’s muted and volume_up
otherwise, but it seems like sending is_volume_muted: false
as data makes the volume_up
fail. Maybe I need a conditional dictionary? Couldn’t find a way of doing that and any help would really be appreciated!
You need to have a choose in the action, then check if unmuted, in which case you would mute etc.
hadov
January 24, 2021, 4:59pm
3
Do you mean like that?
action: >
{%- else -%}
data: {}
{%- endif -%}
Unfortunately this doesn’t work and yields this error message:
Message malformed: expected dictionary @ data['action'][0]
No, much simpler than that.
123
(Taras)
January 24, 2021, 5:13pm
5
- choose:
- conditions: "{{ state_attr('media_player.snapcast_client_bedroom', 'is_volume_muted') }}"
sequence:
- service: media_player.mute
default:
Your first attempt failed for the reason you stated; you can’t supply an unsupported option to a service call.
Your second attempt failed because you can’t include options within a template. A template is used to produce a value for an option.
What I posted is a effectively an if-else statement. If the media_player is muted then do this otherwise do that.
hadov
January 24, 2021, 5:39pm
6
Thanks Taras, that did the trick. And thank you for taking the time to explain what I was doing wrong.
mrgrlscz
(StevenGrlscz)
August 6, 2023, 7:32am
7
Thank you!
By the way i looked for the opposite condition, there it is:
- conditions: {{ not state_attr('media_player.your_player', 'is_volume_muted') }}
