Templating card icon color based on state value in a custom:button-card
Hi everyone, i’d need some help about this thing:
My goal is using a template , in a custom:button-card, to retrieve the state value of a media_player, and using it inside a state value list belonging to another entity(that is, the main one of the card.
so I tried to template the color attribute but it seems that either it can’t accept the templating, either (maybe) inside the template it can’t retrieve the value that is necessary to switch between the 2 colors.
I tried writing just a color value and it works,while the templating doesn’t.
type: custom:button-card
icon: mdi:television-box
entity: input_select.tv_ch_list
state:
  - value: 24
    operator: '=='
    styles:
      icon:
        - color: |
            {%if is_state('media_player.livingroom_tv','on') %}
            '#00ccff'
            {% else %}
            'gray'
            {% endif %}
  - value: 24
    operator: '!='
    color: '#336699'
tap_action:
  action: call-service
  service: input_button.press
    entity_id: input_button.tv_ch_ch
https://community.home-assistant.io/t/how-to-help-us-help-you-or-how-to-ask-a-good-question/114371#oneone-format-it-properly-16
Templates in button-card must be written on JS, not jinja.
Smth like
color: >-
    if (...)
      var xxx;
      return (xxx);
    else
      var yyy;
      return (yyy);
sounds clearer now ,I give a try (Y) thanks!
ok, it was really helpful, and this shows also how much I still have to learn about hassio.
Anyway I solved my problem, this is the way i did:
state:
          - value: 24
            operator: '=='
            styles:
                  icon:
                   - color: >
                             if (states['media_player.livingroom_tv'].state=='on'){
                             return ('#00ccff')
                             }else{
                             return  ('grey')
thank you for the help!
Another way
icon:
                  - color: >
                      [[[ return states['media_player.livingroom_tv'].state =='on'  ? '#00ccff' :  'grey';
yeah, you’re right: the binary option in Js never gets into my head!
