Templating: filter list of entities by area?
I know how to get a list of entities matching certain criteria like this:
  expand(states.light)
  |selectattr('state', 'eq', 'on')
  |map(attribute='entity_id')
  |join(',')
which gives me a list of light entities that are in the on state.
I’m trying to figure out if there’s a way to filter by the area in which the entity is located. Perhaps something like this
  |selectattr('area_id', 'ne', 'Bedroom')
  |join(',')
The use case for this would be wanting to call a service with something like “all lights that are on, but not in the Bedroom area”. Is there any way to do that with a template?
I found the answer, thanks to @frenck’s presentation yesterday (nice job BTW!) - one of the new features added this year (2021.11, specifically) is a filter that does exactly what I needed.
And here are some updated versions of the above code with the new filter in use…
Lights that are on other than in the Bedroom
  |rejectattr('entity_id', 'in', area_entities('Bedroom'))
  |list
Lights that are on, but skip those in the Bedroom IFF someone is in bed:
  |rejectattr(
    is_state('input_boolean.is_someone_in_bed', 'on')
    and 'entity_id', 'in', area_entities('Bedroom')
  |list
Edit: changed |join( ',' ) to |list in the last lines of the code blocks above. Thanks @123
If that’s the use case then the template can simply end with the list filter instead of the join(',') filter.
Cool! Thanks for the suggestion.
I’m using the above as the input for entity_id in the data_template part of a service call. Skipping the join() call cleans things up a bit.
If you wish, you can name it data because data_template was deprecated in favor of simply data several versions ago.
Nice - I still have data_template scattered around in lots of places in my HA YAML. Looks like I need to read the release notes more carefully! Definitely nice not to have to differentiate data and data_template anymore.
Just found this old post.
I was surprised when saw this “rejectattr(… and …)” construction.
Seems that it is only valid when that “is_state()” condition is TRUE.
Otherwise the template should return an error.
This is confirmed by this short code, test it in Dev tools → Template:
          states.light
          | rejectattr(
                true
                and
                'state','eq','on'
          | list
If TRUE - then it return list of lights which are OFF (i.e. ON is rejected).
But if FALSE - it gives an error:
Your code test in Dev Tools → Template test is invalid.
It works if you actually test the state of an input boolean.
input_boolean.sleep_mode is off so the following test is True:
  |selectattr('state', 'eq', 'off')
  |rejectattr(
    is_state('input_boolean.sleep_mode', 'off')
  |list
Change the 'eq','off' to 'on' so the test is False
  |rejectattr(
    is_state('input_boolean.sleep_mode', 'on')
  |list
and it works:
Would this be valid?
service: input_select.select_option
  entity_id: >
    expand(states.select)
    |selectattr('entity_id', 'in', area_entities('Tariffed Utility Meters'))
    |list
  device_id: []
  area_id: []
  option: Step 1
(See below for the correct syntax!)
I have never tried to use a service call meant for an Input Select on a Select entity.
Let us know if it works.
Hmmm. Didn’t work.
Logger: homeassistant.helpers.service
Source: helpers/service.py:244
First occurred: 2:30:28 PM (1 occurrences)
Last logged: 2:30:28 PM
Referenced entities select.bathroom_plugs_annual_energy, select.bathroom_plugs_energy_today, select.bathroom_plugs_monthly_energy, select.bedroom_a_c_monthly_energy, select.coffee_maker_monthly_energy, select.computer_monthly_energy, select.dishwasher_annual_energy, select.dishwasher_energy_today, select.dishwasher_monthly_energy, select.dryer_annual_energy, select.dryer_energy_today, select.dryer_monthly_energy, select.electric_kettle_monthly_energy, select.emporia_total_daily_energy, select.ev_charger_energy_today, select.ev_charging_annual_energy, select.ev_charging_monthly_energy, select.ev_charging_session, select.fridge_annual_energy, select.fridge_energy_today, select.fridge_monthly_energy, select.furnace_annual_energy, select.furnace_energy_today, select.furnace_monthly_energy, select.garage_plugs_annual_energy, select.garage_plugs_energy_today, select.garage_plugs_monthly_energy, select.garburator_annual_energy, select.garburator_energy_today, select.garburator_monthly_energy, select.household_energy_annual, select.household_energy_monthly, select.household_energy_today, select.kitchen_17_monthly_energy, select.kitchen_plugs_17_annual_energy, select.kitchen_plugs_17_energy_today, select.kitchen_plugs_19_annual_energy, select.kitchen_plugs_19_energy_today, select.kitchen_plugs_19_monthly_energy, select.kitchen_plugs_21_annual_energy, select.kitchen_plugs_21_energy_today, select.kitchen_plugs_21_monthly_energy, select.kitchen_plugs_23_energy_today, select.kitchen_plugs_23_monthly_energy, select.kitchn_plugs_23_annual_energy, select.microwave_annual_energy, select.microwave_energy_today, select.microwave_monthly_energy, select.office_monthly_energy, select.outside_plugs_annual_energy, select.outside_plugs_energy_today, select.outside_plugs_monthly_energy, select.paul_s_bedroom_monthly_energy, select.range_annual_energy, select.range_energy_today, select.range_monthly_energy, select.washer_annual_energy, select.washer_energy_today, select.washer_monthly_energy
are missing or not currently available
Could it be because the list is an array of comma separated entities rather than a hyphenated list?
No, it is because you are using the wrong service, as Taras pointed out above.
input_select services do not work with select entities.
These are the services available for select entities:
Doh! :saluting_face:
It works using the correct service for the utility meter select entities…
service: select.select_option
  entity_id: >
   {{ expand(states.select)
    | list
  device_id: []
  area_id: []
  option: "{{ trigger.to_state.state }}"
enabled: true
Thanks.
Here is my new completed automation…
description: ""
  - platform: state
    entity_id:
      - input_select.bc_hydro_rate
    to: Step 2
    variables:
      step_rate: input_number.bchydro_step_2_rate
  - platform: state
    entity_id:
    to: Step 1
    variables:
      step_rate: input_number.bchydro_step_1_rate
condition: []
  - service: input_number.set_value
      value: "{{ states(step_rate) }}"
      entity_id: input_number.bchydro_current_rate
  - service: select.select_option
      entity_id: |
         | list
      device_id: []
      area_id: []
    enabled: true
mode: single
If you want, you can replace all of this:
          | list
with this:
        {{ area_entities('Tariffed Utility Meters')
          | select('match', 'select') | list }}
Meanwhile, I’m over here wondering why expand(states.select) was even used in the first place. I’ve seen this a bunch recently. Expand does nothing on states.<domain>
Ditto.
I assume the original template was created by copying bits from other examples containing the same anti-pattern.
For those unfamiliar with what the original template does:
It starts with the state objects of all select entities in the system, needlessly attempts to convert them into state objects, then whittles it down to match just the entities found in the “Tariffed Utility Meters” area, then extracts their entity_ids.
The suggested template starts with all entity_ids found in the “Tariffed Utility Meters” area then whittles it down to just select entities. Done.
Using Taras’s shorter template and a few other tweaks, this should also do the job for rather fewer lines:
  - platform: state
    entity_id: input_select.bc_hydro_rate
    to:
      - Step 2
      - Step 1
      - Step 1
      - Step 2
      value: "{{ states('input_number.bchydro_' ~ trigger.to_state.state|slugify ~ '_rate') }}"
      entity_id: "{{ area_entities('Tariffed Utility Meters')|select('match','select')|list }}"
Thank you everybody! Here’s my new automation which now includes an email-based trigger for automatic switching plus the above suggestions:
Summary
alias: BCHydro - Rate Change
description: ""
  - platform: numeric_state
    entity_id:
      - sensor.bc_hydro_bill_is_ready
    above: 0
    id: Step 1 Email
    entity_id:
      - sensor.bc_hydro_higher_rate
    above: 0
    id: Step 2 Email
  - platform: state
    entity_id:
    to:
      - Step 1
      - Step 2
      - Step 1
      - Step 2
    enabled: true
condition: []
  - choose:
      - conditions:
          - condition: trigger
            id:
              - Step 1 Email
        sequence:
          - service: input_select.select_option
              option: Step 1
              value: "{{ states('input_number.bchydro_step_1_rate') }}"
      - conditions:
            id:
              - Step 2 Email
        sequence:
              option: Step 2
              value: "{{ states('input_number.bchydro_step_2_rate') }}"
      - conditions:
            id:
              - Select Step
        sequence:
              entity_id: >
                {{ area_entities('Tariffed Utility Meters') | select('match',
                'select') | list }}
              device_id: []
              area_id: []
            enabled: true
mode: queued
max: 2
Multiple triggers and a choose aren’t necessary. Review Troon’s example.
