I am scratching my head on the following: I have a SDS011 sensor on a Tasmota Wemos D1. This spits out the following throught MQTT:
{“Time”:“2019-02-10T08:29:38”,“BMP180”:{“Temperature”:19.4,“Pressure”:987.7},“SHT3X-0x45”:{“Temperature”:19.7,“Humidity”:46.8},“SDS0X1”:{“PM2.5”:1.6,“PM10”:4.6},“PressureUnit”:“hPa”,“TempUnit”:“C”}
I can extract the PM10 value through:
value_template: “{{ value_json[‘SDS0X1’].PM10 }}”
But the problem is that the PM2.5 value looks impossible to extract as value due to the dot.
Any thoughts on how I can get the PM2.5 value through a template?
tom_l
February 10, 2019, 7:55am
2
Does this work?
value_template: "{{ value_json['SDS0X1']['PM2.5'] }}"
That only results in ‘status unknown’…
tom_l
February 10, 2019, 9:31am
4
How about:
value_template: "{{ value_json['SDS0X1'].['PM2.5'] }}"
Apologies! Due to an error from my end (wrong topic) the previous suggestion didn’t work. After correcting it the right syntax is as you indicated: value_template: “{{ value_json[‘SDS0X1’][‘PM2.5’] }}”
Thanks for your help!
tom_l
February 10, 2019, 12:34pm
6
Glad to hear it. That square bracket syntax always confuses me so I wasn’t quite sure.
Hello Frank , can you add full SDS011 sensor yaml configuration? Thanks.
