Hi.
I have a long hallway with 3 motion sensors that activate and deactivate the lights in the hallway based on no motion detected for 30 seconds. In general it works fine, but of course if you are standing still in the hallway or having little movement the lights will go off and you should start moving your arms like you are the director of a philarmonic. Also, its not very consume efficient since most of the time the lights should not be on for more that 5-10 seconds, so I’m triying to improve this.
The hallway has 3 motion sensors that detect motion perfectly comming out of any room, and every room has a motion sensor that detects motion when comming into the room. The three sensors are grouped with a helper.
What I would like to achieve is that:
- The hallway light turns on when the motion group is on
- The hallway light turns off when comming into a room and does not detect motion in the hallway for lets say 5 seconds
- The hallway light will not turn off unless I get into a room or past 5 minutes as a failsafe
- That failsafe of 5 minutes will not run if the door leading out of the house at the end of the hallway is open
I’ve managed so far to turn on the light whith motion and turn it off when comming into a room, but it fails from time to time since the timeout on my sensors is 5 seconds and if I come into a room just to pick up something and get out, the automating will not render the condition as true, since the hallway gruop has not had time to be off.
Please check my automation to see if anyone can come with a solution.
- id: Turn on and off hallway lights with motion sensor
alias: Turn on and off hallway lights with motion sensor
description: ''
- entity_id: binary_sensor.sensores_de_movimiento_del_pasillo
platform: state
to: 'on'
condition: []
- data: {}
service: light.turn_on
entity_id:
- light.luz_del_pasillo
- wait_for_trigger:
- platform: state
to: 'off'
- condition: and
conditions:
- condition: or
conditions:
- type: is_motion
condition: device
device_id: 73e48e0f6c3f7d365cd776e6bf6ff9f2
entity_id: binary_sensor.sensor_de_movimiento_de_la_cocina_occupancy
domain: binary_sensor
- type: is_motion
condition: device
device_id: 32f91552ae4bd4296b7c5e3487d815b0
entity_id: binary_sensor.sensor_de_movimiento_del_bano_de_juan_occupancy
- type: is_motion
condition: device
device_id: 4feb07e46cb0fa3fba0e54d179df1ce7
entity_id: binary_sensor.sensor_de_movimiento_del_bano_de_amaia_occupancy
- type: is_motion
condition: device
device_id: b8ed49319b3048d22928c2c89c6b464a
entity_id: binary_sensor.sensor_de_movimiento_del_cuarto_de_la_entrada_occupancy
- type: is_motion
condition: device
device_id: 1cccca38a8e65723fcdcf7965e625101
entity_id: binary_sensor.sensor_de_movimiento_del_salon_occupancy
- service: light.turn_off
data: {}
entity_id:
- light.fairy_lights
mode: restart
