tombom
(tom)
1
Hi
i am trying to create an automation that stores last volume level of my AVR and another to restore it later.
the first part already works via input_text helper (couldn’t get it to work with input_number)
what i am having trouble with is the latter part, restoring this value. i can control the Denon Volume via simple URL-calls, like so:
"http://DENON-IP/goform/formiPhoneAppDirect.xml?MV35"
in this example it will change volume to “35”, works like a charm.
so for my intents and purposes i tried the following in config.yaml. but it doesn’t work
denon_set_last_vol:
url: "http://DENON-IP/goform/formiPhoneAppDirect.xml?MV"
method: GET
headers:
content_type: 'text/plain'
payload: '{{states('input_text.denon_last_volume_text')|float}}'
neither does it work if i try the following for testing purposes
payload: '35'
maybe somebody has an idea. much appreciated. thanks!
Hellis81
(Hellis81)
2
I think you need:
denon_set_last_vol:
url: "http://DENON-IP/goform/formiPhoneAppDirect.xml?MV{{ states('input_text.denon_last_volume_text')|int}}"
method: GET
headers:
tombom
(tom)
3
thanks for the reply!!
i had already tried this but your suggestion still allowed me to find the answer.
The Denon AVR only accepts whole numbers (no floats) in my testing i had always used 29.5 as a value and it never worked.
appended float() | round(0) to the template and now it works
thanks again! i love this community
Hellis81
(Hellis81)
4
So what was the final code?
Others might find it useful
tombom
(tom)
5
rest_command:
denon_set_last_vol:
url: "http://DENON-IP/goform/formiPhoneAppDirect.xml?MV{{ states('input_number.denon_last_volume_number') | float() | round(0)}}"
method: GET
headers:
(got the automation working w input_number as well in the process (instead of input_text))
Hellis81
(Hellis81)
6
Float and round(0) is the same thing as int.
