I recently created a template using a technique that I haven’t seen posted in this forum (and a search produced no results). It might be useful to others so I’ll explain how I used it.
I want to show a list of open doors. Each entity’s friendly_name
ends with the word “Door”. I don’t want the list of open doors to contain the word “Door” repeatedly, like this:
Front Door, Rear Door, Garage Door
I want it to look like this:
Front, Rear, Garage
That means I need to remove the last five characters from each entity’s friendly_name
(one space character plus the word Door
). What would be a simple way to do that?
Here’s what I did:
sensors:
open_doors:
friendly_name: 'Open Doors'
value_template: >
{{ [ states.binary_sensor.front_door,
states.binary_sensor.rear_door,
states.binary_sensor.garage_door,
states.binary_sensor.side_door ]
| selectattr('state', 'eq', 'on')
| map(attribute='name')
| map('replace', ' Door', '')
| list | join(', ') }}
The technique that I haven’t seen posted here (perhaps only because the use-case is so specific) is this one:
The map
filter applies the replace
filter to each item in the received generator object. I’ve used map
to do things like extract a specific attribute from each item, like this:
or to convert each item to an integer value, by applying a simple filter like this:
map('int')
but this is the first time I considered using map
to apply a more complex filter that takes several arguments, like replace
Anyway, I hope this can help others who may have a similar requirement.
