I just tried the following and of course it doesn’t work as it is no where close to the templating feature.
- action:
{% for i in range(21) %}
- data:
entity_id: light.wohnzimmer_decke
brightness: {{ 200 - i * 9 }}
color_temp: {{ 377 + i * 4 }}
service: light.turn_on
- delay: 00:01:00
{% endfor %}
alias: Sundown
condition:
condition: time
weekday:
- sun
- mon
- tue
- wed
- thu
- at: '22:00'
platform: time
My goal is just to replace lots of repetetive lines with a loop. Is something like this possible with the templating of Home Assistant? If not, would it be possible in another way?
Thanks!
Is there any update to the above query, I am looking for the same. My use case is that when I receive a text from Telegram, I need to parse that message and call appropriate service and related actions. I can do that by repeating the if statements in service_template and the exactly the same statement in data_template. This is to ensure that for the called ‘service’ the exact corresponding ‘data’ is called. Now, this is just repeating the same conditions and I would like to see if there is something like ‘action_template’ where the service and data can be called in single if. My code below
The following code works fine
- id: '1234'
alias: receive a text from Telegram and call appropriate service
platform: event
event_type: telegram_text
- service_template: >
{% if state in states.input_text.on_states.state %}
switch.turn_on
{% elif state in states.input_text.off_states.state %}
media_player.turn_off
{% endif %}
data_template:
entity_id: >
{% if state in states.input_text.on_states.state %} # Repeated if statement from service_template
switch.mediarelay
media_player.kodi
{% endif %}
What I want to achieve is something like this
- id: '1234'
platform: event
action_template: >
- service_template: switch.turn_on
data_template:
entity_id: switch.mediarelay
- service_template: media_player.turn_off
data_template:
entity_id: media_player.kodi
{% endif %)
The scope of a template you create for a given option, like service_template, is limited to that option. It cannot be made into some kind of global macro and referenced from another option, like data_template.
Each option is its own little planet and there’s no interplanetary communication.
Noted on the above. However, is there any other way this could be achieved. The idea is not just to avoid the repeated if statement, but also to develop a generic template which could take the pair of service_template & data_template together. Like in my earlier example (shown below), the data_template for the service_template for “Switch” always expects a “entity_id”. However, if I want to use Service of ‘Notify.telegram’ , it would expect a data_template of ‘message’ and not ‘Entity_id’. Any other clever way of doing this?
switch.turn_on
{% endif %}
data_template:
entity_id: >
switch.mediarelay
media_player.kodi
{% endif %}
