I have several thermostats activated with geofencing. When I set a thermostat, it often doesn’t accept the new value from the first attempt. So I have to set it a few times to the same value before it’s accepted.
I’ve created a script with 2 fields/variables and a loop until the new value is accepted in the thermostat. But I get an error on the conversion to float from the field.
alias: Set Temperature
sequence:
- repeat:
sequence:
- service: climate.set_temperature
temperature: "{{temperature}}"
entity_id: climate.{{device}}
- delay:
hours: 0
minutes: 0
seconds: 6
milliseconds: 0
until:
- condition: template
value_template: >-
{{states("sensor.room_setpoint_thermostat_""{{device}}") | float ==
"{{temperature}}" | float}} = true
enabled: true
mode: restart
fields:
device:
selector:
text: null
temperature:
selector:
text: null
default: "19"
The error:
Logger: homeassistant.helpers.script
Source: helpers/script.py:791
First occurred: 10:36:15
Last logged: 11:12:37
Error in ‘until[0]’ evaluation: In ‘template’ condition: ValueError: Template error: float got invalid input ‘unknown’ when rendering template ‘{{states(“sensor.room_setpoint_thermostat_”“{{device}}”) | float == “{{temperature}}” | float}} = true’ but no default was specified
How can I get the template to work properly?
THX
